2001 A4 2.8 Quattro smoking from left rear side of engine
Old Nov 16, 2010 | 08:00 AM
  #21
dyazdani's Avatar
Originally Posted by mzo0163
How much more difficult is it to replace the cam seals along with the VC seals? I have the same issue and im not sure if its the cam seals leaking or just the VC seals. If its not much more work then ill just buy the kit and do everything. I saw the writeup for the VC seal reaplace and it doesnt look to difficult but if i gatta take off my bumper and start pulling belts off and such to redo the cam seals thats probly out of my league.
You can do the VC seals without taking anything out except the air box. The cam seal job requires you to pull the bumper, various pulleys/tensioners, timing belt, housing, etc. A tool rental is recommended as well, I got mine from BlauParts (twice).
You can do the VC gaskets in an hour or so, depending on how much cleaning of the gasket surfaces and old RTV you have to get out. The timing belt and cam seal job will take all day, maybe 6-8 hours if you don't have any problems.
These times are in my experience only, others may have done better.
twopedalwarrior
Mar 17, 2015 07:02 AM
jbgreen2
Feb 14, 2012 06:15 PM
james8593
Nov 14, 2010 09:30 PM
satishtadi
Nov 1, 2006 08:07 PM
Sp33d07
Jan 6, 2006 06:58 PM
