2001 Audi A4 quattro 1.8T Engine problem
Old May 23, 2010 | 08:36 PM
epell11's Avatar
Default 2001 Audi A4 quattro 1.8T Engine problem
So i am having a problem with my engine...there is a loud knocking sound in the engine and there is no oil in the top of the engine. The oil pressure light is not on and I have already tried an oil change. I was told that the oil pickup tube is clogged and replacing this and the oil pump can solve the problem. Is this accurate or do i have a larger problem?
Old May 23, 2010 | 08:41 PM
Mike-2ptzero's Avatar
If you have no oil getting to the head then it is most likely a clogged oil pick up or the great sludge issue.
Have you had someone put on a gauge to test how much oil pressure you have when it is running?
Old May 23, 2010 | 08:56 PM
epell11's Avatar
well i just bought the car but the previous owner said that the oil pressure was very close to normal when it is running
projectquattro
9
Aug 3, 2009 10:03 PM
presideo
Oct 24, 2008 01:05 AM
markpen23
Mar 15, 2008 08:58 PM
nimgnay
Jul 19, 2007 01:10 PM
alex verve
Jun 16, 2005 03:07 AM
