View Poll Results: Which of the problems is it likely to be that causes my 2nd gear to not work?
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2nd gear problems!?
i guess its not my synchro cuz i cant put it into second without pushing in the clutch, and when i push in the clutch and put it in second, then release the clutch, 2nd gear pops out and grinds. i just need a new transmission i think.
A transmission that jumps out of gear may be due to bent, binding or loose shift linkage, a loose transmission or clutch housing, worn or damaged input shaft bearings, broken motor mount, worn tapered gear teeth or synchronizer hub splines, loose shifter fork or rails, interlock hardware that’s broken or missing, or excessive end play or runout in the output shaft or countergear.
Not necessarily Audi specific, but may be a good place to start looking.
