30v head swap?
Old Sep 10, 2009 | 02:02 PM
  #31
Mr. Phil's Avatar
How is it an inline 6 when the cylinders are on opposites sides sitting 3x3
Originally Posted by rcheing
Phil, the VR6 is not a "V' engine, it's an inline 6.
Old Sep 10, 2009 | 02:05 PM
  #32
Andrew149's Avatar
haha omg
Old Sep 10, 2009 | 03:36 PM
  #33
Mr. Phil's Avatar
No not omg.... Answer the question its pretty simple, u claim its an inline 6 and not a v6 so explain
Old Sep 10, 2009 | 04:05 PM
  #34
rcheing's Avatar
It is not sitting 3x3 on each side. According to the link I posted, the name VR6 comes from the german word "Reihenmotor" which translates as row engine or straight engine. It is like a SOHC with each cylinder in a staggered setup but in a straight line. Furthermore, the VR6 has the same firing order as a inline 6 engine. It uses one cylinder bank and one cylinder head. For more information please check out the following link: http://en.wikipedia.org/wiki/VR6_engine
Old Sep 10, 2009 | 04:13 PM
  #35
Mr. Phil's Avatar
yes i read all that... but not once did it say this motor is an inline six they said it is a staggered setup and is very close to a "vee" set up, but has the same firing order as a straight 6... so like i said its not a straight 6
Old Sep 10, 2009 | 04:15 PM
  #36
ImTheDevil's Avatar
The original idea of the VR6 is that it allowed a 6-cylinder engine to fit in the space designed for an inline-4 - essentially it was a packaging exercise to allow more engine in less space. Technically it's a V6 because it has interspersed and alternating cylinders with a 15-degree bank angle, but in all practicality it's an inline engine. It was commonly referred to as an "inline-V" even. Yes, the bank angle does quslify it as a V6 but realistically it's an inline engine.
Old Sep 10, 2009 | 04:21 PM
  #37
Mr. Phil's Avatar
but they arent in a straight line.. thats the point... the inline 6 or "straight" 6 is jsut that.... straight... while these may not sit directly opposite of each other they also do not run straight through either so it is neither a v or an inline... so i guess inline v is the only thing that can work haha
  #38
rcheing's Avatar
Phil you're right in that it doesn't say that it's a full inline 6 engine because it does indeed use a staggered setup with the cylinders arranged in different angles. Here's where I disagree with you, the german name says its a straight engine and since the cylinders are not mounted under two separate cylinder heads, like "ImTheDevil" says, realistically, it's an inline 6 with a twist.
Old Sep 10, 2009 | 04:28 PM
  #39
Mr. Phil's Avatar
WELL he also said as did the article since they are mounted at angles... i think 10.5 and 15 degrees... its not straight either... so the only logical name im going to accept is inline V or ******* racecar haha
Old Sep 10, 2009 | 05:35 PM
  #40
Siena's Avatar
The VR6 is an inline 6. The cylinders may be staggered, yes, but it's not a true V. The name also suggests inline 6, which is exactly what it is, SOHC with a common head.
