97 1.8t Throwing Multiple DTCs, I Need Some Help Please
Using a Vag-Com and VCDS Lite to scan the car for codes since the Check Engine light came on along with the In-2, ABS, and BRAKE indicators
Getting very close to my wife's due date so Im pressed for time! Scannner showed the following:
VCDS-Lite Version: Release 1.1
Sunday, 06 May 2012, 10:02:31.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 907 558 M
Component: 1.8L R4/5VT MOTR AT D01
Coding: 06051
Shop #: WSC 42025
VCID: 3B09B4EF3A6B
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-10 - Please Register/Activate - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8D0 927 156 L
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
VCID: 361FA5DB0149
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.LBL
Controller: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 4175
Coding: 0265109001
Shop #: BB 34175
VCID: 321799CBED21
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
I had a coolant leak coming from the plug on the coolant flange so I replaced that and got new o-rings. Did I damage a spark plug or coil by leaning on them during the install? For the Brake Light Switch, does this Implausible Signal mean a replacement? And the ABS Wheel Speed Sensor, I just replaced both rear brake rotors a week ago. 2 days ago, the passenger side was smoking while I was driving because of a poorly seated wheel bearing. Caliper was jammed to the rotor and smoking hot lol Took it apart and seated them myself... After re-installing everything, it flashed this code. Im stuck, I need some help please. Im new to Audi's, only had it for 3 weeks
Only just now did I find the radiator drain plug lol
Getting very close to my wife's due date so Im pressed for time! Scannner showed the following:VCDS-Lite Version: Release 1.1
Coding: 06051
Shop #: WSC 42025
VCID: 3B09B4EF3A6B
4 Faults Found:
Coding: 00000
Shop #: WSC 00000
VCID: 361FA5DB0149
1 Fault Found:
Coding: 0265109001
Shop #: BB 34175
VCID: 321799CBED21
1 Fault Found:
I had this code (00287 - ABS Wheel Speed Sensor; Rear Right (G44) ) about 3 weeks ago with a solid ABS light,after i replaced all 4 rotors and brake pads.
Turns out it the tip of the sensor was covered in dirt,just cleaned it with a steel brush,cleared the code with my vag-com and the ABS light never came back on,problem solved.
You either have the same issue as i did or you damaged the sensor and need it replace it with a new one.
Hm...cooking a sensor? I like that terminology
Got out of church, went to start the car to go home. No more misfire... Hm...
Pleased nonetheless.
Still got a Brake Light Switch and ABS speed sensor to go... And a freshly recharged AC system that isn't blowing cold air because the AC Clutch isnt engaging. And a passenger side window that doesnt go up or down.
After that its some minor body work and Ill be bringing my SataJet out of retirement to give this A4 a new, fresh paintjob
Pleased nonetheless. Still got a Brake Light Switch and ABS speed sensor to go... And a freshly recharged AC system that isn't blowing cold air because the AC Clutch isnt engaging. And a passenger side window that doesnt go up or down.
Definitely
I love working on cars in general, though my gift seems to be making them look pretty through layers of colored and clear solvents
For the brake light switch issue, see the following link under Special Notes: 00526 - Ross-Tech Wiki My understanding is that basically if you step on the brake before running VAG-COM, you won't get this code unless there really is something wrong with the switch. I read that on a blog/posting somewhere. It has been true for my car. Hope all went well with the impending due date!
