97 1.8t Throwing Multiple DTCs, I Need Some Help Please
Old May 6, 2012 | 04:14 PM
PacificA4's Avatar
Default 97 1.8t Throwing Multiple DTCs, I Need Some Help Please
Using a Vag-Com and VCDS Lite to scan the car for codes since the Check Engine light came on along with the In-2, ABS, and BRAKE indicators Getting very close to my wife's due date so Im pressed for time! Scannner showed the following:
VCDS-Lite Version: Release 1.1
Sunday, 06 May 2012, 10:02:31.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 907 558 M
Component: 1.8L R4/5VT MOTR AT D01
Coding: 06051
Shop #: WSC 42025
VCID: 3B09B4EF3A6B
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-10 - Please Register/Activate - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8D0 927 156 L
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 00000
VCID: 361FA5DB0149
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.LBL
Controller: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 4175
Coding: 0265109001
Shop #: BB 34175
VCID: 321799CBED21
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
I had a coolant leak coming from the plug on the coolant flange so I replaced that and got new o-rings. Did I damage a spark plug or coil by leaning on them during the install? For the Brake Light Switch, does this Implausible Signal mean a replacement? And the ABS Wheel Speed Sensor, I just replaced both rear brake rotors a week ago. 2 days ago, the passenger side was smoking while I was driving because of a poorly seated wheel bearing. Caliper was jammed to the rotor and smoking hot lol Took it apart and seated them myself... After re-installing everything, it flashed this code. Im stuck, I need some help please. Im new to Audi's, only had it for 3 weeks Only just now did I find the radiator drain plug lol
Old May 6, 2012 | 06:15 PM
morpheous's Avatar
I had this code (00287 - ABS Wheel Speed Sensor; Rear Right (G44) ) about 3 weeks ago with a solid ABS light,after i replaced all 4 rotors and brake pads.
Turns out it the tip of the sensor was covered in dirt,just cleaned it with a steel brush,cleared the code with my vag-com and the ABS light never came back on,problem solved.
You either have the same issue as i did or you damaged the sensor and need it replace it with a new one.
Old May 6, 2012 | 06:50 PM
M5S5's Avatar
Tech Certified
Swap #4 cylinder coil with another cylinder , erase fault codes & see what comes back.
Looks like you will need a brake light switch also.
Old May 6, 2012 | 08:23 PM
ImTheDevil's Avatar
Agreed on M5S5's assessment, and to what Morpheous said, it's either that or the seized caliper cooked the sensor and ruined it.
Old May 6, 2012 | 11:17 PM
PacificA4's Avatar
Cleaned the sensor with a wire bush and sprayed connector cleaner, now instead of coming from 7MPH and up, its on when I start the car, goes off, then comes on again. Hm...lol I think I see a new sensor in my future
I was thinking that too. Will give it a try.
Hm...cooking a sensor? I like that terminology
Old May 6, 2012 | 11:40 PM
ImTheDevil's Avatar
Lol well when something gets heated that badly, all bets are off.
Old May 7, 2012 | 01:49 AM
PacificA4's Avatar
Got out of church, went to start the car to go home. No more misfire... Hm... Pleased nonetheless.
Still got a Brake Light Switch and ABS speed sensor to go... And a freshly recharged AC system that isn't blowing cold air because the AC Clutch isnt engaging. And a passenger side window that doesnt go up or down. After that its some minor body work and Ill be bringing my SataJet out of retirement to give this A4 a new, fresh paintjob
Old May 7, 2012 | 02:16 AM
morpheous's Avatar
Post some pictures,so we all could see the work in progress.
Old May 7, 2012 | 04:15 AM
PacificA4's Avatar
Definitely I love working on cars in general, though my gift seems to be making them look pretty through layers of colored and clear solvents
Old May 31, 2012 | 05:23 PM
pradipsahu's Avatar
Default Brake Light Switch
For the brake light switch issue, see the following link under Special Notes: 00526 - Ross-Tech Wiki My understanding is that basically if you step on the brake before running VAG-COM, you won't get this code unless there really is something wrong with the switch. I read that on a blog/posting somewhere. It has been true for my car. Hope all went well with the impending due date!
