97 2.8 wont start
Old May 3, 2010 | 01:50 AM
raa4's Avatar
Default 97 2.8 wont start
I have a 97 2.8 a4 that the only way it will start is if I have the gas pedel to the floor once it starts if I take my foot off the pedel it dies. I tried hanging the igniter and nothing the car will not start. The only code that it gives is mass air sensor code. Any ideas?
Thanks
Old May 3, 2010 | 02:32 PM
CCA4's Avatar
unplug the MAF and try it again.
Old May 3, 2010 | 07:06 PM
raa4's Avatar
Thanks for the response I tried that and still does the samething
Old May 3, 2010 | 07:12 PM
CCA4's Avatar
could be the ignition control module, do you have access to VAG-COM?
Old May 3, 2010 | 08:23 PM
Andrew149's Avatar
sounds like you pump isnt working your prob forcing gas in it by opening the gas pedal all the way and the engine trying to suck it in test your pump
Old May 3, 2010 | 08:34 PM
CCA4's Avatar
S.a.p.?
Old May 3, 2010 | 08:43 PM
Andrew149's Avatar
SAP what do you mean by that even if his maf is bad the car will start no matter what its a gas issue to the engine if the car starts and turns off thats always a gas issue and we all know the pumps do go bad mby his filter is clogged
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
