98 audi a4 2.8l Transmission
Old Jan 26, 2011 | 07:38 PM
Josh299's Avatar
Default 98 audi a4 2.8l Transmission
Hi how are you doing. Does anyone know what the difference is between the 1998 audi a4 DRN and the DTV transmission is. Im wondering if the bellhousing is different. I assume that the gear ratio is different. Please let me know all the info you can thanks. I need a tranny and i have a good DTV complete drivetrain wondering if i can swap it into my other car
thanks
josh
Old Jan 27, 2011 | 03:46 AM
Andrew149's Avatar
if the codes dont match up dont bother unless you want to mess with it to get it to work
Old Jan 27, 2011 | 07:54 AM
vtraudt's Avatar
I cannot comment on DRN vs. DTV (I don't know the details of the DTV).
The 96 A4 2.8 quattro auto had (for unknown) reason a DRN installed. It is supposed to have a CJP. Since the DRN was not working (turns out all friction packs were worn; mechancial parts all good), I changed it and installed a CJP.
I could NOT find ANY difference between DRN and CJP.
Both, the DRN and the CJP ran with the same trans module (I never changed it).
TCM Module and Software
http://i853.photobucket.com/albums/a...libration1.jpg
Engine and Transmission Codes
http://i853.photobucket.com/albums/a...onTCMcodes.jpg
If your TCM matches (location is under the passenger seat carpet), I venture a guess it would work.
I have the DRN housing sitting here if you need anything off it to compare with your DTV (PM me if you need anything).
I would also check the 2 round connectors going from the trans to the engine/PCM. One comes from the internal valve body, the other from the multi-function range switch (gear indicator) (8 pin or 10 pin).
You should be able to find gearing information by looking up the detailed specs for the car by year and engine size.
Old Jan 27, 2011 | 08:35 AM
vtraudt's Avatar
Default Gear Ratio 1998 1.8 vs. 2.8
I found the following gear ratio. Comparing them, you'll note that only the final drive gear ratio is different (3.3 for the 2.8, 3.7 for the 1.8T), the trans itself are the same.
Gear ratio of 1998 Audi A4 1.8T auto:
Gear ratio of 1998 Audi A4 2.8 auto:
Old Jan 27, 2011 | 08:52 AM
vtraudt's Avatar
Default 1998 Audi A4 auto trans codes used
These are the various trans codes for 1998 A4 auto trans.
You also should check the torque converter for fit (diameter, thickness, input shaft, flywheel bolt pattern).
Old Jan 27, 2011 | 09:30 AM
Andrew149's Avatar
is your 98 a triptronic or non trip?
Old Jan 27, 2011 | 11:07 AM
Josh299's Avatar
My 98 is a triptonic.. Both transmissions are still in the car.. I'm trying to find out if the bellhousings are the same.. I was told by a guy that he thought they were the same
Old Jan 27, 2011 | 11:36 AM
Mike-2ptzero's Avatar
all the bell housings should be the same.
Old Jan 27, 2011 | 03:04 PM
daedaestoy's Avatar
is it possible to put the 1.8 tranny in the 2.8 car since it has a higher gear ratio to get more low end out of it?
Old Jan 27, 2011 | 04:17 PM
Yes you can but if it is a TIP you need to make sure the transmission controller will work and you need to make sure the final drives are the same.
dhprice
May 7, 2013 11:27 PM
moises maldonado
Jul 21, 2011 04:58 PM
50401a4
Jun 20, 2011 10:51 AM
the G man
Oct 13, 2008 09:09 PM
