98 Audi A4 stuck in park. Diagnosed and Fixed!
Old Nov 18, 2011 | 06:14 PM
mctruth3's Avatar
Default 98 Audi A4 stuck in park. Diagnosed and Fixed!
I had a little scare in my first week of ownership with my Audi A4. The shifter was stuck in park and the foot light wouldn't go off to acknowledge that I was pressing the brake. I checked the brake lights and they were out so I switched the brake light fuse(13) with another one of the same kind. Sure enough it solved the problem and the shifter is back to normal.
So this is a message to everyone who's shifter gets stuck in park:
Before you do anything complicated or spend x amount of dollars for some to diagnose the problem 1) Check to see if the brake lights work, 2) If not change fuse number 13 (it's a red #10 small fuze).
Old Nov 19, 2011 | 10:15 AM
jdahlen24's Avatar
Good job, sir. I do a lot of troubleshooting at work(web sys admin) and I always try the easy things first. You just proved that that's the best way to approach a problem.
Old Nov 19, 2011 | 10:42 AM
foxracing4500's Avatar
deleted
Old Nov 19, 2011 | 02:19 PM
mctruth3's Avatar
Yeah it probably was #13 because obd would probably have more to do with the computer I'm guessing.
Jdahlen that was my main purpose for posting this because the internet is flooded with diagnosing this problem starting with the most complicated and most expensive. I saw one post say to take off the shifter apron...supposedly from an audi tech...
Also even if we are not mechanically inclined(I'm far from it) we can still eliminate the things that are easy before taking it to the shop and paying x amount to diagnose and fix.
SparkssA4
Feb 23, 2021 12:47 PM
mmerrick
B8 Models
Jan 13, 2018 09:19 PM
foxracing4500
Oct 2, 2011 05:07 PM
Havyk
Sep 28, 2011 07:00 PM
liv2wrshp
Oct 22, 2007 10:43 PM
