'99 A4 Engine Oil
Old Aug 17, 2010 | 11:28 PM
dudemar's Avatar
Default '99 A4 Engine Oil
Hello all,
I noticed that my engine oil was running low so I added a quart of Mobil 1 0W-30. I was in a bit of a hurry and couldn't remember if my mechanic added 10W-40 or 10W-30 during my last oil change, so i went with the latter. Here's my question: will 10W-30 damage/hurt my engine? The oil is now slightly darker, but not my much. The engine also seems to work a bit harder during idle. For reference it's a 2.8L.
Thanks for any help.
PS- Another quick question: should I check the oil when the engine's warm or cold? I've heard different answers so just wanted to be clear on that one.
Old Aug 18, 2010 | 12:55 AM
morpheous's Avatar
Originally Posted by dudemar
Hello all,
I don't know the answer to the first question but i do for the second.
You always check your oil,when the car is cold,because all the oil has dropped down in the pan and will give a proper reading,opposed to the engine being hot and all the oil is still in the cylinders/pistons,dripping down into the pan,not allowing for a accurate reading.
Old Aug 18, 2010 | 08:43 AM
CCA4's Avatar
I run Mobil1 0 W40, car seems to like it well enough. PLENTY of oil threads, use teh searchez.
Old Aug 18, 2010 | 10:38 AM
ObnoxiousDrunk's Avatar
should be alright
Old Aug 18, 2010 | 01:48 PM
ImTheDevil's Avatar
I run conventional 5W30 in my 99 2.8 with no issues.
Old Aug 18, 2010 | 03:02 PM
There are a TON of opinions on what others deem necessary to use. I believe 5W30 is common to run. Depending on what climate you live, a different viscosity level may be necessary.
Personally I use 5W30 Quaker State Synthetic because it's cheaper than Mobil1....hope this thread won't devolve into "that brand sucks you should use this".
Old Aug 18, 2010 | 03:08 PM
onepoint8tee's Avatar
Originally Posted by ObnoxiousDrunk
I use 5W30 Quaker State Synthetic.
That brand sucks. You should use Amsoil
Old Aug 18, 2010 | 05:40 PM
Hahahahaha.....see!!!!
Old Aug 18, 2010 | 05:59 PM
CCA4's Avatar
I ran 5W30 and 5W40 previously, but 0W40 seems to produce the smoothest idle. Could just be my imagination though lol
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
