99 a4 steering wheel grinding noise
Old Mar 24, 2012 | 03:02 PM
Mojo3's Avatar
Default 99 a4 steering wheel grinding noise
happens only when i turn left
see video (turn up vol u can clearly hear what I am talking about)
I can steer fine its just annoying loud noise.
Any ideas on problem?
Audi a4 Steering Wheel Grinding Noise - YouTube
ty
Old Mar 24, 2012 | 07:34 PM
morpheous's Avatar
I'd top off or change the power steering fluid,if its low. Could be the power steering pump itself,if the fluid is not low or dirty.
Old Mar 24, 2012 | 07:38 PM
M5S5's Avatar
Tech Certified
ty
Don't make left turns!
No really , check your fluid. Also check the power steering system clamps. The hoses will squish a little after time & can cause leaks that suck air & airate the power steering fluid.
Old Mar 24, 2012 | 10:11 PM
Mojo3's Avatar
Thanks for responses, why would it only do it when turning left? lol That could still be the pump or fluid?
Old Mar 25, 2012 | 10:43 AM
M5S5's Avatar
Tech Certified
Yes it could be the fluid. CHF11s only.
Old Mar 25, 2012 | 10:52 PM
FishEye's Avatar
It sounds like it could be your power steering fluid... Like M5S5 said only use Pentosin CHF 11S fluid only. You can get it at the dealer or at a auto parts store. It also might sound like your wheel hitting the bumper or some fender piece. If the car is lowered or modified from original height/wheel size then i would also check that out
Davidiot
Dec 20, 2011 10:07 AM
czwalga
Feb 19, 2008 02:55 PM
Stoned Gecko
Dec 29, 2006 08:33 PM
a4mad
Aug 21, 2006 09:03 PM
ryan
Mar 6, 2005 11:48 AM
