A4 Remote programming with 1 key - possible?
Old Feb 12, 2008 | 02:14 PM
jasmix's Avatar
Default A4 Remote programming with 1 key - possible?
I bought the car with one key/remote but its not programmed...I've read that you need atleast two....
is there away to get this done without another key?
Old Feb 12, 2008 | 08:55 PM
Trey25's Avatar
Default RE: A4 Remote programming with 1 key - possible?
dealership
Old Feb 13, 2008 | 01:17 PM
justinclarke's Avatar
Nope... as above^^
Unless you can get that key cut onto new bladekey somewhere.
Old Feb 13, 2008 | 05:31 PM
diesela4's Avatar
does the key start the engine fine ( as in the immobiliser accepts the key) then just stick the key into the car turn to lights on deash then off, try buttons, worked for me when i changed the battery.
but if you need a NEW key then its the dealers unless you hace the code for the immobiliser then you can use VAGCOM. this code comes on a plastic tag that came with the keys when 1st bought.
carce
Sep 18, 2019 05:22 AM
galenA6
Mar 1, 2009 02:39 PM
null
Feb 15, 2007 05:10 AM
Agro
Oct 26, 2006 01:37 PM
powerboat
Feb 26, 2005 12:28 PM
