A8/tt brake upgrade
Old 04-01-2012, 07:41 PM
Adamgt's Avatar
I've got some used, good condition drilled A8 rotors. $50 plus shipping and they're yours. Email me.
Old 04-01-2012, 08:34 PM
ImTheDevil's Avatar
I've had it for over 4 years. That and HIDs were the best bang for the buck I've gotten from this car. Bones is correct that the larger rotor contributes. It has more mass to dissipate heat. You're also correct in the larger radius from center to pad - the larger torque-arm effect improves the stopping power. And believe me for such a mild and inexpensive upgrade, the improvements are significant.
Old 04-01-2012, 10:25 PM
villacorta32's Avatar
Awesome!
Old 04-02-2012, 07:40 AM
jonbonesjones's Avatar
Moderator
or you can do what i did and swap s4 brakes theres an extra piston in there and they are bigger than the a8 rotor
Old 04-02-2012, 08:46 AM
CCA4's Avatar
I run the A8/TT setup as well. That, combined with a good quality pad, will get you a noticeable improvement in stopping power.
Old 06-09-2012, 12:04 AM
So I finally ended up doing this upgrade and must say it is well worth it. Got the carriers for 100 bucks at a wrecking yard, but now I have tt calipers I don't need, lol. I did my bestfriend's timing belt job on his 1.8t passat and as payment I told him to just buy me the rotors, so we picked up some Bosch rotors yesterday. This setup is sweet, only problem is that I want to upgrade the rear now,
Old 06-09-2012, 09:23 AM
Moderator
300mm rears i have them t compliment my s4 up front. insane difference.
Caliper Bracket, Rear B5 300x22mm Upgrade - 034 MOTORSPORT
make sure you either buy their overpriced ss line or get a custom one THE STOCK SIZE WILL NOT FIT. ask me how i know
  #18
Old 06-11-2012, 02:54 PM
dubbed_up_daz's Avatar
how do you know?
  #19
Old 06-11-2012, 03:40 PM
Sheasta's Avatar
So can you do a8 rotor, tt carrier and s4 caliper for extra piston?
  #20
Old 06-11-2012, 03:52 PM
ImTheDevil's Avatar
No, the S4 upgrade is completely separate and different.
Quick Reply: A8/tt brake upgrade
