Ac problems
Old Aug 7, 2013 | 04:32 PM
Expplucky's Avatar
Default Ac problems
So its 106 here almost everyday i recently recharged my ac after i dumped it during a t-belt job, so when im at a red light the compressor kicks and makes the car feel kind of like its missfiring and at some points it stops blowing cold air completely
so what other than changing out my compressor can i do to fix this?
Old Aug 7, 2013 | 05:25 PM
xxNeverG1veUpxx's Avatar
Hey Expplucky, you may want to check if your low and high pressures are correct. I overcharged mine one summer and my compressor would kick on constantly and would bog my car down. I got the pressures in the correct range and it fixed it for me. I fixed it by pushing a screwdriver on each of the valves and let some out. I know it's not the right way, but hey, sometimes you gotta improvise
Another thing you might check out is you may have a weak coilpack that may be exacerbated by the added power needed to run the A/C. Not sure but someone around here with more knowledge than me will probably chime in.
Old Aug 7, 2013 | 06:34 PM
Expplucky's Avatar
would you happen to know the correct pressure?
Old Aug 8, 2013 | 10:54 AM
I believe the low pressure needs to be between 25-40 PSI and the high pressure between 225-250 PSI.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
