AEB problem
Old Jun 28, 2008 | 01:18 AM
tln708726's Avatar
Default RE: AEB problem
wow Tweaked, opionion are like butt holes, everyone has them at least auditech 79 trys to help and and be a butt
Old Jun 28, 2008 | 11:59 AM
Tweaked's Avatar
ORIGINAL: tln708726
Uh, what? It was a mechanic joke, no one is being a "butt." I also don't see how me saying that a dead miss a cyl. 3 raising EGTs and killing boost is not helpful in some way.
Hah, you said "butt."
Old Jun 29, 2008 | 11:56 PM
a4r6's Avatar
Thank you...
I guess its time to swap coils. I just don't understand why the coil would spark fine under 10 pounds of boost and be screwed up at higher boost. *shrug*
Thank you for your help, I already checked my ICM. Its fine.
Old Jun 30, 2008 | 02:16 AM
a4r6's Avatar
Alright well in the process of swapping coils I decided to check my ICM and swap the coils. I pulled the ICM out and it wouldn't read any resistance on any of the cylinders. I know I was doing it right because I took my old ICM and ran that one the same way coming up with no ohms in cylinder two (the reason why I bought a new one).. Any ideas as to why that would happen with the one that I now know works fine on my car..
Originally as I said my miss was in cylinder 3. I swapped pack 2 and 3 and now my miss in cylinder 2. So I guess these packs can go bad...
Thanks for your help.
Stu
Old Jun 30, 2008 | 02:21 AM
a4r6's Avatar
Just in case anyone is interested in how I checked my ICM I used this http://forums.audiworld.com/a4/msgs/1594531.phtml
Old Jun 30, 2008 | 05:06 PM
auditech79's Avatar
Well i can explain why the coil pack only miss-fires at higher boost at least.
Each coil pack has its own primary and secondary coil built into each one, if one of the coils developes corrosion on either the coil or at the point of the connection between the plug and coil it can make it harder for the coil to create a spark. An open in the coil also creates resistance because it has to jump a gap inside the coil.
Now the engine at idle only needs a little bit of spark to keep the engine running because there isn't hardly any pressure inside the cylinder. When the turbo creates boost, increased pressure is inside the cylinder meaning it needs a higher spark to ignite the mixture which is why its only missing under boost.
Glad you found the problem.
Old Jun 30, 2008 | 05:22 PM
Tweaked's Avatar
Nice work.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
