Help me pass emissions
Old Jun 26, 2008 | 03:45 PM
btl1990's Avatar
Default Help me pass emissions
I have a 1997 Audi A4 Quattro. I went to get my inspection and it turns out that I failed. My check engine light is either missing or burnt out. I have the following codes:
P0116- ECT Range/Performance Problem
P0150- O2 Sensor B2 S1 Circuit Malfunction
P0130- O2 Sensor B1 S1 Malf
P0401- EGR Flow Insufficient
I found the O2 sensors online but don't know which ones I need because there are three that you can purchase. Also what are the P0116 and P0401 codes? How do I go about fixing them? Is there any way that the O2 sensors are good and just loose or corroded? Any help is appreciated[sm=feedback.gif]
Old Jun 26, 2008 | 04:13 PM
andreigbs's Avatar
Member
Default RE: Help me pass emissions
Plug those error codes on this page: http://wiki.ross-tech.com/index.php/Main_Page and see what the possible solutions are.
Old Jun 26, 2008 | 04:32 PM
ImTheDevil's Avatar
For the O2 sensors, call ECS Tuning and ask them - if you give them your VIN number, they can tell you which ones you need. The P0116 sounds like a coolant temperature failure (likely cause is the coolant temp sensor - they're known problem areas on these cars). The P0401 is your EGR system. It could be a faulty or clogged EGR valve, it could be a broken vacuum line, etc - that may require some poking and probing to be sure you localize the problem correctly.
Old Jun 27, 2008 | 04:36 PM
btl1990's Avatar
Thanks
Old Jun 27, 2008 | 06:21 PM
gabe711's Avatar
just pay them extra $$$ and they'll pass you for sure!
or like upstate said, your best bet is to call ecs
Old Jun 27, 2008 | 06:23 PM
auditech79's Avatar
www.purems.com is generally cheaper for O2 sensors than ECS
Old Jun 28, 2008 | 02:55 PM
mschwister12's Avatar
Are you running a cold air intake on your engine? Replacing the stock MAFS could resolve the performance part of the emmisions atleast.
Old Jun 29, 2008 | 04:50 PM
btl1990's Avatar
Stock intake. Why would this resolve the issue without replacing the O2 sensors?
Old Jun 30, 2008 | 09:40 PM
Sorry. Didn't read throrough enough. I just know that's a common prob.
mikeeboy82
Sep 22, 2011 04:37 PM
audiup
Jan 11, 2011 10:34 PM
1998A4Turbo
May 8, 2009 07:29 PM
Rosati
May 7, 2007 09:14 PM
newcaligirl
Nov 16, 2006 12:57 PM
