Alright guys, I need some help.
Old Sep 2, 2011 | 08:31 PM
DOC_DEPALMA's Avatar
Originally Posted by Tweaked
^Bad, dangerous, no-no!!!
Is it a tiptronic? If so, be sure the TCM is plugged in and code-free. If you've yanked the engine, you've unplugged a lot of stuff... something is probably not plugged in. Crank position sensor, TCM, coil pack...
Also, I believe ln 2 is just a service interval light.
Yeah as I was doing it I remembered learning about Arcs in current and such. But honestly at this point if the car killed me it would just be ironic. I dont give a **** anymore. Where was I? Oh yeah, it's a manual.
Can you think of a systematic way for me to check each connection? I have SEVERE ADD and it's hard for me to stay on track with things like this.
Old Sep 2, 2011 | 08:33 PM
Tweaked's Avatar
Haha, OK. I believe I have an ignition procedure on my Laptop. Let me see if I can get it for you. Standby.
Old Sep 2, 2011 | 09:09 PM
Tweaked's Avatar
Doc, check your PMs.
Old Sep 2, 2011 | 10:11 PM
ImTheDevil's Avatar
In2 is an inspection minder. I have never seen "redir" before - it seems like a blanket failure to talk to the ECU. Maybe a grounding issue or a blown ECU-related fuse or fusible link that's keeping the ECU from powering up or going into a run mode...?
Old Sep 3, 2011 | 11:44 AM
Devil - I'll try and check it out, any pointers as far as where to start etc..?
Old Sep 4, 2011 | 11:31 PM
airguard350's Avatar
Tech Guru
I've always touched my spark plugs to metal one at a time. No arc for me.
CL AUDI EOUS
Nov 23, 2021 01:42 AM
osin34
Jan 18, 2010 12:23 AM
Rob_B
Oct 22, 2007 12:08 PM
Riko
Jan 10, 2007 07:50 AM
audisloff
Sep 25, 2005 11:20 PM
