Amp and sub wiring in non bose
Old Jan 6, 2009 | 03:31 AM
B5 owns's Avatar
Default Amp and sub wiring in non bose
Well im trying to figure out what I should do. Should I use a high/low converter and splice the RCAs into the two rear speakers? There is no amp in non bose systems right? I also need the wiring diagram so I know where to splice the remote on/off and the RCAs into, if anyone has it then that would be great.
Old Jan 6, 2009 | 01:48 PM
audiabstract's Avatar
https://www.audiforums.com/forum/sho...wiring+diagram
I did mine. it was pretty straight forward. I think there might also be a DIY on audidiy.com.
Old Jan 6, 2009 | 03:51 PM
B5 owns's Avatar
thanks alot, I searched but all I found was the bose diys..
Old Jan 24, 2009 | 07:21 PM
hwong's Avatar
Hi, new here. But just finished setting up my system keeping the stock unit. Mine is the non-bose system in an '01 and there is an amp attached to the rear speakers. I disconnected those and splice rca cables to wires and ran a separate amp. I also replaced the rear deck speakers with some Pioneers. Not top of the line but affordable and 100% better than the stock. When it gets warmer I'll take some pictures. If you still need the wiring set up, I can detail it for you.
madrid09
Mar 13, 2014 08:59 PM
deeman8087
Dec 12, 2012 03:13 PM
sound227
Jan 22, 2008 10:23 AM
casegolf99
May 10, 2007 02:32 PM
DenimTT
Jun 16, 2006 01:01 PM
