Another timing belt!
Old May 19, 2010 | 05:54 PM
yamaharider11161990's Avatar
Default Another timing belt!
Ok so i am doing my timing belt/ waterpump replacement on my car cause i found my waterpump was leaking. I found the kit on baum sports. The kit has everything but the time belt tensioner.... my question is should i purchase this seperate? Or do they not go bad as often on the 12v v6's. Again i dont want to purchase anything i am not in need of. The way it seems is it is common for you to replace it on the 1.8t..... Also what specialty tools would i need to do the job? i heard the cam holder is not necessary. But what about the crank holder pin? Is there anything else needed besides the basic handtools? Thank you very much
Old May 19, 2010 | 06:04 PM
CCA4's Avatar
Usually its the tensioner that goes and not the belt, you're definitely gonna wanna replace it. Why do you say "another" timing belt? Try the kit on Blauparts, comes with the tensioner and is reasonably priced
EDIT: Just re-read your original post, sorry i missed the last question. You don't need to BUY the cam alignment tool, but i'd definitely suggest making one if you have the means.
Old May 19, 2010 | 06:37 PM
jiggleo's Avatar
and don't forget the beer
Old May 19, 2010 | 06:44 PM
02A6Beau's Avatar
I would also suggest replacing the tensioner while you are "in there". Why tempt fate?
Cam locking bar is absolutely not necessary unless you are going to do seals too. Just make sure you mark EVERYTHING on the cam and crank sprockets after you get the motor set TDC and before you start removing the timing belt/components. If anything moves it will then be super obvious and real easy to rotate individual sprockets back EXACTLY where they belong.
Old May 19, 2010 | 09:31 PM
MarkR540's Avatar
IMO. replace everything and be worry free unless you is a gamblin man.
Old May 19, 2010 | 09:35 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I agree.
Old May 20, 2010 | 12:56 AM
Alrght thanks alot guys that helps out. and what am i marking the spprocket in corrolation to the motor? or to the belt.. beacuse the belt will be replaced... And CCA4 how would i go about making one. Again thanks
Old May 20, 2010 | 01:10 AM
Also when you say tensioner are you meaning the tensioner pulleys? or about the hydraulic tensioner. Because i dont see the hydraulic one in the kit on blausports. but if your talking about the tensioner pulleys i was going to for sure replace those..... just dont know about the hydraulic tensioner
Old May 20, 2010 | 07:08 AM
CCA4's Avatar
Hmmm just checked, they only have hydraulic dampers for the 30v?
Old May 20, 2010 | 07:24 AM
ImTheDevil's Avatar
Replace everything that relates to tension. Mark the belt to the sprocket to the engine.
