Another Tire Rubbing Question
Old Mar 10, 2008 | 11:38 PM
kolbs_91's Avatar
Default Another Tire Rubbing Question
I'm now being told by a friend that the tires I have ordered (215/50-17) will rub with the suspension setup I'm running (Neuspeed Race / Bilstein Sport non-grooved).
And thought??
I've got a feeling I'm going to be screwed in one way or another. [&o]
Old Mar 10, 2008 | 11:47 PM
hiwords's Avatar
Default RE: Another Tire Rubbing Question
i don't think it should but i could be wrong. i personally would have gotta 215/45/17 though, it's closer to the stock size.
http://www.miata.net/garage/tirecalc.html
Old Mar 11, 2008 | 12:05 AM
kolbs_91's Avatar
ORIGINAL: hiwords
That's what I'm wishing I would've gotten, just to be safe. When I picked out the wheels and tires I wanted the guy that worked there chose the tire size, and I forgot to mention that I was lowered. I'm going to try to call them tomorrow and get the size changed.
Old Mar 11, 2008 | 12:12 AM
ImTheDevil's Avatar
Even lowered, you shouldn't have a problem as long as the wheel offset is right. Those tires are very marginally wider than stock, so I wouldn't worry. At most, you might rub just a bit with the wheel turned as far as it'll go. Think of it this way - I'm running 235-45-17s (admittedly at stock ride height) and I have zero rub at all, anywhere in the turning range and not even at full strut compression. You're running narrower than that, and close to the same rolling diameter. Even lowered (if you're lowered correctly, with struts meant for lowering springs), you should be fine. I would try and get the 215-45s if you can, just because of what hiwords said (keeping the rolling diameter as close to stock as possible, for better accuracy of odometer and speedometer), but even if you can't, I don't think you'll have trouble.
Old Mar 11, 2008 | 12:22 AM
kolbs_91's Avatar
ORIGINAL: UpstateNYA4
Thanks - great information. All I can do is call ASAP tomorrow and tell them before they mount them, which should be interesting as I'm in school from 8:02 until 3:12. [:@]
Old Mar 11, 2008 | 12:33 AM
ImTheDevil's Avatar
Take a "pee break" at the appropriate time and call them
Old Mar 11, 2008 | 12:35 AM
kolbs_91's Avatar
Haha, yeah; it might come down to that.
Old Mar 11, 2008 | 12:58 AM
ImTheDevil's Avatar
Hey, you do what you have to do right? I doubt that the few minutes you'd miss of the lecture is going to make or break your grade
Old Mar 11, 2008 | 01:01 AM
kolbs_91's Avatar
Yeah, probably not. Hehe. I might just sit in my car and make the call at 8:00 when they open, then be a few minutes late to first hour - that'll make things even easier.
Old Mar 14, 2008 | 02:06 AM
turbo kraut's Avatar
Tech Guru
where are the pix?
ddebruyn
Mar 25, 2012 07:20 PM
themikeindy
Nov 11, 2010 01:35 PM
gator
Apr 8, 2009 10:07 PM
kolbs_91
Mar 9, 2008 11:22 AM
