antifreeze/coolant
Old Apr 1, 2008 | 03:46 PM
  #21
chaos92287's Avatar
Default RE: antifreeze/coolant
ORIGINAL: turbo kraut
ok, i just looked in here......now here is my question..... i did my fmic and when i did so i was getting a leak from my ps cooler........ well, i pulled the one time clip and it all ran out...... so i stoped in and put in some hydralic ps fluid cause that is what the a4 calls for...... so you are saying this could be bad?
should i drain it and get some audi ps fluid?
What I wanted to find out was:
> why is the Audi spec'd fluid SO expensive?
> Is it REALLY that different?
> WHAT makes it special?
> In the process I have learnt a lot about hydraulic systems and oils in
> general. Even if I don't find the "Shangri La of hydraulic fluids" I am
> better for the experience as I have educated myself.
> Audi specified certain qualities for the hydraulic oil for their systems
> based on the requirements of the system components built by ZF, Girling
> and others. Pentosin created the product. We'll just talk about the
> original CHF 7.1 to keep it simple.
> Audi spec'd a fluid that is mineral based, with a density of .84 @ 20C,
> flash point of 130C, Pour point greater than -60C, a viscosity index of
> 340 (which means it will not change viscosity much over a given temp
> range, as I found out thanks to other listers) , viscosity of less than
> 1100 @ -40C, 18 @ 40C and 6 @ 100C. (this info is taken from the Pentosin
> website) They labeled this product G002000.
> You must agree that you don't need G002000. You need an oil that is
> mineral based, with a density of .84 @ 20C, flash point of 130C, Pour
> point greater than -60C, a viscosity index of 340, viscosity of less than
Those viscosity figures now make sense to me, thanks to info from the web
and listers.
> In my research I found that virtually all oil manufacturers cross
> reference the spec's on their products, to the spec's from other
> manufacturers. For example Mobil XXXNNN meets or exceeds the requirements
> of Caterpillar NNXXXNN. Hence they are interchangeable. Caterpillar
> tells you to use only product CAT NNXXXNN, but there would be no harm in
> using Mobil XXXNNN because they are the same thing.
> I did not find 1 single manufacturer who cross referenced to G002000.
> Maybe I should have stopped right there, but I didn't as I was curious.
> The 'magic' of G002000 appears to be the viscosity index which indicates
> the effect of temperature change on the viscosity of a fluid. My
> understanding is that a higher viscosity index (VI) indicates a fluid
> whose viscosity changes less over a temperature range. Higher number is
> good, lower number is bad. CH 7.1 has a VI of 340 so this is our
> benchmark and likely why no other oils "meet or exceed" the specs of
> G002000 (at least no oils that I have found yet). Apparently the
> engineers at Pentosin managed to reduce the effect of temperature on their
> hydraulic oil whereas other companies either haven't bothered, or haven't
> yet figured it out.
WRT to the Mobil DTE specifically, there should be no problem whatsoever for
those in moderate climates, but those of us in the great white north (on
both sides of the pond) shouldn't use it because it will damage the system
components over time. The high viscosity at low temps will likely starve
the pump and or create cavitation, both of which are very harmful.
There are other hydraulic oils out there that meet all the other spec's of
CHF 7.1 and 11S except for the viscosity index so you could use them
seasonally - probably ATF in summer and a winter hydraulic fluid. Generally
these would be unacceptable because if you are using a winter hydraulic
fluid, it likely will become too thin as the engine bay heats up. This will
result in damage due to lack of proper lubrication.
Thanks for reading and thanks to those who gave input and information. And
fix the leaks and stick with the G002000.
Old Apr 1, 2008 | 04:43 PM
  #22
turbo kraut's Avatar
Tech Guru
so chaos.... most of that was over my head, so does it mean i can run other than audi ps fluid?
Old Apr 1, 2008 | 05:21 PM
  #23
chaos92287's Avatar
it means as long as the specs of the fluid meet the specs of g2000 then you should be fine. according to that person they searched and couldn't find any fluid that met the specs of g2000. nothing had a viscosity index high enough. if you live in warmer climate, it doesn't matter as much, but if you live up north the higher pressure of audi's steering system combined with the lower viscosity index means your steering rack will get worn out over time and need replacing.
so basically audi's ps fluid is the best and designed to work with audi's higher pressure steering system. if you use an inferior fluid you will wear out the system (usually within a year) and its expensive as hell to replace
Old Apr 1, 2008 | 05:23 PM
  #24
Tech Guru
then i will swing by this week and pick up a bottle just to be safe
Old Apr 2, 2008 | 02:19 PM
  #25
sirfalconx's Avatar
My car had that green sh*t in it when it came from the stealership. it seemed fine, but I changed it anyway because I hate the smell of the green stuff.
Old Apr 2, 2008 | 02:34 PM
  #26
chaos92287's Avatar
found another good read. this time on coolant.
Inorganic Acid Technology (IAT)
This is the common green stuff original equipment manufacturers have used for over 70 years. Ethylene glycol is its base chemical, and there are silicate and phosphate additives that make it compatible with copper, brass, cast-iron and aluminum cooling system components. Manufacturers recommended that you change the green IAT antifreeze every 36,000 miles or three years. IAT coolant was used in GM vehicles until 1994. Chrysler used green IAT fluid until 2001, as did Ford (with the exception of some 1999 models that used OAT blue coolant which must be purchased from Ford).
Organic Acid Technology (OAT)
Commonly referred in GM vehicles by the brand name, Dex-Cool or to other manufacturers as propylene glycol. GM introduced Dex-Cool in 1995 as an "extended life" coolant, though most GM car owners and repair shops are finding that Dex-Cool is good for only about three to five years before it needs to be replaced. But because of the additives in the Dex-Cool orange antifreeze, you do not want to substitute the old reliable green coolant. Usually (but not always) dyed orange or yellow so you could tell the difference between OAT and IAT, this coolant has similar corrosion protection to the green stuff; however, it is designed to be slower acting, hence the extended-life moniker. It is made from a propylene glycol base, which makes it less poisonous than conventional IAT for children and pets. OAT, when spilled or lost due to a boil-over, is much less harmful to the environment. In addition to its use in 1996 model year and newer GM cars and trucks, OAT is also used in 1996 to 2001 Audi, Land Rover, Nissan, Mazda, Toyota, Honda, Kia, Jaguar, Saab and Porsche. Manufacturers are now recommending your OAT coolant be changed every five years. OAT coolants are currently readily available from most auto parts stores.
Hybrid Organic Acid Technology
(HOAT)
This coolant is usually dyed yellow but comes in other colors like green, pink, blue, red and orange, which leads to a lot of confusion. One way to know for sure if you are getting HOAT will be by the packaging. Manufacturers often refer to this antifreeze as "global" and will indicate on the bottle that it meets or exceeds the specification "G-05" for most European cars and G-11 or G-12 for Volkswagen and Audi. Hybrid antifreeze has added silicates for aluminum protection and is advertised as having a five-year change interval. Normally, HOAT coolants are specified for vehicles newer than 2002, specifically Mercedes, Volvo, Ford, VW, Audi, Chrysler, BMW and Saab.
The use of OAT and HOAT coolants can extend the life of rubber coolant hoses, because they conduct less electrochemical degradation or ECD than the conventional green antifreeze. ECD is the process by which the motion of coolant and water through your engine creates an electrical charge similar to a galvanic battery. This electrical charge degrades both rubber and metal parts in the cooling system from the inside out. ECD can be attributed as the cause of many premature coolant system failures.
Volkswagen, Audi and other European vehicles use antifreeze that can be blue, pink or red in color. Most of these are available under the brand name Pentosin in 1.5-liter bottles. The pink and red are specifically designed for alloy engines and both meet the required G-12 coolant specification. The blue is also for alloy-based engines, but with a different pH level, and is equivalent to the G-11 rating.
You will find other types of antifreeze available for heavy-duty trucks. Both pink antifreeze (no, not the same stuff as used in the toilet in your camper at the lake house) and red are sold for truck use. These should not be confused with the pink or red HOAT coolants used on imported vehicles because they are designed specifically for trucks. These coolants will usually say "low-silicate" and "final charge" or "fleet charge" on them. They will do you no good in your passenger car because the lubrication and metal protection additives are separate in large truck cooling systems.
So what should you use? Manufacturers will tell you to stick with what is in there. You can have the cooling system cleaned with a coolant filtration system. This is a very popular tool in repair shops today and will recycle your antifreeze. Component chemicals can be re-added to boost its boiling and freezing point and adjust the pH of the cooling system back to specifications. The most accurate tool for measuring OAT and HOAT potency is a refractometer, which is an expensive piece of equipment, so you should have the coolant checked by a service station before deciding whether it should be replaced or refurbished. If you are low on fluid or have a leak, a general rule of thumb is, green IAT is always replaced by green IAT coolant.
Dex-Cool or an OAT product with equivalent specifications is always necessary to replace orange or yellow organic-based antifreeze. For the rainbow of colors of HOAT, your only substitute is the yellow or amber global antifreeze. Global coolant will not change the color of the stuff that is already in there.
If original red, blue or pink antifreeze is desired, you must get these from a Pentosin supplier or your car dealer. Can you run organic coolant in an earlier vehicle? Yes and no. OAT will work if your radiator is aluminum and you flush your entire cooling system with water and completely refill with OAT, but there are some issues with the interaction between organic coolants and lead solder, so using OAT in a copper radiator is not recommended. In short, antifreeze these days is a buyer beware deal. Check your owner's manual for the correct fluid, and read the label on your replacement coolant carefully to ensure it meets with the required specifications.
So if your ever in a spot where you can't get g12, an OAT like dex-cool would be the best replacement. Green stuff should be your last choice. and g12 should always be used when possible.
cutting corners usually costs you more money in the long run
Old Apr 2, 2008 | 10:09 PM
  #27
ImTheDevil's Avatar
Good info - bookmarked
Old Apr 3, 2008 | 01:38 AM
  #28
feerocknok's Avatar
Dex-cool is the devil. Looks good on paper; sucks in real life.
Old Apr 3, 2008 | 01:34 PM
  #29
chaos92287's Avatar
it doesn't suck. it just doesn't come anywhere near close to be safe to change it every 150k. thats just ridiculous.
Old Apr 3, 2008 | 01:59 PM
  #30
feerocknok's Avatar
ORIGINAL: chaos92287
It causes iron oxide, which destroys everything it touches; freeze plugs, radiator cap, coolant reservoir, radiator, water pump, thermostat. The overheating can cause engine and transmission failures.
15k miles on a Blazer cap:
50k:
The radiator:
Couple more:
I'm not a fan.
