Automatic Windows
Old Jan 1, 2009 | 02:22 PM
Schwalbe181's Avatar
Default Automatic Windows
I went out today to drive my car and i had to roll the window down, and it went down by itself like normal, but when i went to pull it up, i had to hold it instead of normally just the one click. I had my doors apart the other day for speaker issues but i put them all back right, and since then and before now they worked properly. What could be the problem? Its only reached a high of 9 degrees the last 48 hours, could that do anything to it?
Old Jan 1, 2009 | 05:27 PM
bump. anyone??
Old Jan 1, 2009 | 08:57 PM
hiwords's Avatar
did you unplug your battery? if so you have to roll them down and up and then it'll go back to normal. or at least it should. the rear windows won't do that unless you cut and splice a couple of wires
Old Jan 1, 2009 | 09:13 PM
Jc61990's Avatar
yea you need to re program them. just roll them all the way down, then all the way up, then the 1 touch should be back
Old Jan 1, 2009 | 10:48 PM
i did it twice right whenit happened and nothing worked. ill go out again tomorrow and try it. Thanks!
Old Jan 2, 2009 | 01:15 AM
ImTheDevil's Avatar
He forgot one step in the directions - when you roll them back up, hold the button til they're all the way up, then release and quickly click the button up again, and release. Then your windows' one-touch-up feature will be back.
Old Jan 2, 2009 | 10:45 PM
okay ill try that upstate, i did the other way and nothing happened, thanks for the advice
Old Jan 2, 2009 | 10:55 PM
Jc61990's Avatar
yes hes right, i had to reprogram mine today my batt died, its all the way down, realease, click down once and all the way up release click up once. rinse and repeat for the other 3
striker451
Sep 4, 2009 03:44 PM
MyDreamCar
Aug 2, 2009 06:43 PM
CTown
Sep 17, 2007 12:07 AM
fcamargo6thave
Apr 6, 2007 04:20 PM
EuroS4
Jul 19, 2005 10:37 PM
