Axle Oil Seal
Old Dec 12, 2009 | 03:37 PM
motodiver13's Avatar
Default Axle Oil Seal
Hi All, I have a '00 A4 1.8T Quattro. I have a trans fluid leak that I am pretty sure is coming from the axle seal on the front drivers side. I know I need to remove the CV shaft but am not sure where the seal is beyond that. Any tips would be appreciated. Thanks
Old Dec 12, 2009 | 06:49 PM
hiwords's Avatar
to remove the shaft, you need to use a 12 point 8mm allen bit. i believe it's 8mm. pm ImTheDevil to make sure. then you need to turn the wheel to the right and the shaft should come out. don't let the shaft fall on the floor though so either have 2 ppl or put something soft under the shaft
Old Dec 12, 2009 | 07:27 PM
thanks. do you know where to go after I get the axle out?
savantv
Dec 30, 2012 01:51 AM
01quattro
Mar 27, 2012 04:21 PM
abydielsgli
Mar 10, 2011 02:16 AM
vooo5269
Oct 1, 2010 08:46 PM
tsd02
Oct 19, 2008 03:02 AM
