Bad ecm OBD2?
Old Mar 21, 2013 | 01:32 PM
norcal89451's Avatar
Default Bad ecm OBD2?
Whenever i got CEL hook scanner to the obd2 port it wont read what my CEL is.. what could this mean? Bad ecm? Wiring? And i was also lookin into getting a tune i wonder if that would still be even possible? Ty.
Old Mar 21, 2013 | 01:41 PM
EthanB5( auditek)'s Avatar
Tech Certified
sounds like you possibly have a bad ABS module, unplug your ABS module and rescan it.
it should read.. if that is your problem
Old Mar 21, 2013 | 05:04 PM
Mad Cow's Avatar
Installing an aftermarket deck improperly could also cause this, or a damaged cluster. Pull the cluster, ABS and radio fuses one by one and see if you can connect.
Old Mar 22, 2013 | 02:46 PM
Wheres the abs module located at?
Old Mar 22, 2013 | 08:08 PM
Tech Certified
right next to your washer fluid tank there is the abs mechanical unit and attacked to it is the module. you should see all the brake lines running to it. it should be a black conector harness..
are you familar with Audi electrical connections?. there is a tab you have to pull out.. it slides towards the front bumper, then the connctor should come right off.
Old Mar 22, 2013 | 11:10 PM
Can i buy a new one at an auto parts? Instead of tryin to attempt to re-sauder it..?
Old Mar 23, 2013 | 07:39 PM
Tech Certified
are you talking about your ecm or the abs module?
i would n try to repair an ecm.... thats something i would say you have to buy a new one or a known good used one.
you can buy rebuild kits for your abs module.
but it depends if the actual abs unit is bad or if the module is bad.
the rebuild kit is a new module you just bolt up to your abs unit they are like $800
i dont know of any after market companies make repair kits for them or not.
Old Mar 24, 2013 | 01:22 AM
Holy ****
Old Mar 24, 2013 | 02:54 PM
Tech Certified
were you able to get your car scanned?
Old Mar 24, 2013 | 03:03 PM
jacobboudrie's Avatar
could be both
Princess G
Jan 11, 2014 01:08 AM
urbonek
Mar 13, 2012 09:02 AM
AudiCoupeV6
B7 Models
Jan 4, 2011 09:59 PM
aarono_120
May 9, 2010 10:15 PM
loopin
Sep 9, 2008 05:37 PM
