Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Obd2
Old Oct 9, 2009 | 04:41 PM
Princess G's Avatar
Default Obd2
Hey ....I failed inspection because the MV computer couldnt connect to the OBD2 computer in my car. I just had my car scanned with VagCom and the guy took off all codes that he found on my car. I'm not sure if he found anything with the OBD2 ...would that have even shown up or is the OBD2 computer just a separate issue? I'm afraid to go back and have it inspected because I heard you get a ticket for failing 3 times and I already went twice .
Does anyone have any advice to give me. ?? Thanks in advance!
P.S. The faults found are my abs light thats on and the 17831 was a flex pipe that I had replaced.
Old Oct 9, 2009 | 04:45 PM
Princess G's Avatar
Here is a copy of my scan ......
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 BA
Component: 2.8L V6/5V G 0050
Coding: 07252
Shop #: WSC 08265
2 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Readiness: 0000 0001
Address 02: Auto Trans Labels:
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
No fault code found.
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 H
Component: Airbag Front+Seite 2002
Coding: 00106
Shop #: WSC 01505
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487
Component: E Lenkrad Elektronik D03
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 980 LX
Component: C5-KOMBIINSTR. VDO D13
Coding: 02262
Shop #: WSC 01505
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
Thursday,08,October,2009,15:55:20:31669
VCDS Version: Release 908.0
Data version: 20090911
76 77
Coding: 07252
Shop #: WSC 08265
1 Fault Found:
P1606 - 35-00 - -
Readiness: 0110 1101
Note: Excessive Comm Errors
Coding: 00106
Shop #: WSC 01505
Coding: 02262
Shop #: WSC 01505
Coding: 15885
Shop #: WSC 02325
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00006
Shop #: WSC 02325
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00003
End ---------------------------------------------------------------------
Old Jan 8, 2013 | 10:40 AM
nnk's Avatar
nnk
what type of scanner did you use or can any one suggest a good one. I have 05 allroad.
Old Feb 20, 2013 | 09:31 PM
sss4749's Avatar
My Garage is empty, I find this on Google garage repair data, garage tools, garage repair database
Will I be able to buy it here
Old Feb 21, 2013 | 05:39 PM
tofast2belast's Avatar
were the codes cleared right before you went for the emissions test? ifso this would cause the issue you have experienced. if you can, drive around for a bit and hook up the vag com cable-> go to module 1(engine)> check the readyness option while the engine is running. if they say passed then your fine. depending on your state you can have 1 failed or incomplete.
Old Dec 19, 2013 | 08:30 AM
octeobd2's Avatar
i use MaxiService VAG505,i buy it half year ago.it easy to operation. here is the link VW/AUDI/SEAT/SKODA Scan Tool VAG505
hope is help to you!~
Old Jan 10, 2014 | 01:01 AM
a9680rz1's Avatar
Default Mileage needed to ready catalyst,evap and o2...please help
I have a 2001 A6 2.8...Ive put almost 300 miles and o2,evap and catalyst still show as incomplete...does anyone know how many miles it takes to ready these? Thanks in advance
Old Jan 10, 2014 | 09:04 AM
About 30-40 miles. Replace o2 sensor and see if that fixes the o2 readiness. You can pass with the evap incomplete.
What state are you in? I know in some states such as PA you can pass if mil is off and 2 readiness failed/incomplete
Old Jan 11, 2014 | 01:08 AM
a9680rz1's Avatar
Im in NH and naturally in this state any code that isnt unsupported has to be complete....im just getting worried that i need cats...does anyone know a cheap way to fix cats...thats legal lol
norcal89451
Mar 24, 2013 03:03 PM
urbonek
Mar 13, 2012 09:02 AM
AudiCoupeV6
B7 Models
Jan 4, 2011 09:59 PM
aarono_120
May 9, 2010 10:15 PM
loopin
Sep 9, 2008 05:37 PM
