bad things happen to mr. clutchy...
Old Jul 31, 2011 | 07:09 PM
redline380's Avatar
Legal Moderator
Default bad things happen to mr. clutchy...
so im driving home and am shifting petty quick from first to second and the clutch pedal goes soft. It went into second gear but after that i couldnt get it out of gear or into another. after i stopper i got the car in neutral and I couldnt select another gear. the stick just wouldnt go and the car seemed to want to move forward when i was trying to select a gear even with the clutch pedal all the way in (mind you it has regained feeling at this point). after shutting the car off, i can select a gear, start it up and move, but not shift. luckily i was able to limp it home as i was only a mile a way in third gear. question: what happened? my thoughts are either throwout bearing, slave cylinder, or needs a new clutch altogether. the clutch holds fine when in gear, but i just cant shift. the stick is locked until the car shuts off. help is greatly appreciated.
if you cant tell from the photo, which you should cause you like audis, its a 01 1.8tqm
Old Jul 31, 2011 | 11:39 PM
ImTheDevil's Avatar
This exact thing happened to Meloman recently - his throwout bearing was bad.
Old Sep 16, 2011 | 08:44 PM
redline380's Avatar
Legal Moderator
for future reference its was the pressure plate. its was literally in four pieces. really surprised the car still moved. had an ecs tuning clutch kit installed and its back on the road
Old Sep 22, 2011 | 07:43 AM
CantA4rd's Avatar
Good info to know. How iss new ECS clutch?
freddyuk
Sep 17, 2010 05:29 AM
Wintermute
Jul 9, 2008 12:59 AM
nrthwds34
Dec 7, 2005 12:36 AM
