Battery problems! Please help!
Old Nov 12, 2009 | 07:37 PM
a4audia4's Avatar
Default Battery problems! Please help!
I bought a battery in July, and now my multimeter is reading 11.5V with no load.
My alternator isn't so great. I know that because when i replaced the battery in July, the multimeter read the battery at 13.8V with the engine running, and 12V with no load. From what I read, I guess it's supposed to read 14.5~ when there's a load across it? But I recharged the battery in September-- knowing that the alternator was weak.
So, starting today, the car won't run and the reading is 11.5V with out a load. Would the battery die like that because the alternator is running weak, even though I recharge the battery periodically? Or is there something else? Like a bad ground-- would that cause the battery to die quickly?
Really appreciate your help, thanks ahead.
'97 A4 quattro 2.8L 12v
Old Nov 12, 2009 | 09:06 PM
Andrew149's Avatar
replace the battery
Old Nov 12, 2009 | 09:16 PM
ObnoxiousDrunk's Avatar
^ I'll see your replace the battery and raise you a replace the alternator too. Should do the trick.
erniegib
Oct 10, 2008 03:09 PM
PwrDriftr
Jan 11, 2008 04:11 PM
gkb
Dec 23, 2007 04:33 PM
jonga6
Jun 27, 2005 01:26 PM
lalaland
Mar 3, 2005 09:49 AM
