Bigger Rear Swaybar
Old Aug 5, 2008 | 08:32 PM
Dallas09's Avatar
Default Bigger Rear Swaybar
Alright, so i was thinking id try putting in a bigger rear sway bar (ive heard this would increase oversteer a little, which is what im looking for). If i have stock sport suspension, how big should i get it?
Old Aug 6, 2008 | 10:20 AM
Tweaked's Avatar
A larger rear bar and a smaller front bar will generally increase understeer because the rear doesn't want to rotate. A smaller rear bar will allow the car to rotate and put more weight on the rear corners, inducing oversteer (think drifting), but the car can become squirrely on the street if it's too drastic.
Unless you have a specific application or use for your car on the track, you should aim for making the car more neutral, which can be accomplished by getting a Neuspeed or Hotchkis set of big sway bars. Do the front and the rear and replace the rear endlinks with metal ones.
Old Aug 6, 2008 | 11:26 AM
Dallas09's Avatar
Sounds good, thanks for the help, i guess i had it backwards. Ill check neuspeed and hotchkis out.
EastTNPharmD
May 20, 2013 11:20 PM
Mr. Merk
Mar 23, 2012 04:25 PM
redmond1501
Mar 7, 2011 10:53 AM
superdooperme
Jun 5, 2009 04:47 AM
yesss4
Mar 27, 2007 02:54 AM
