blown motor need help
Old Apr 11, 2011 | 08:49 PM
capuanofire's Avatar
Default blown motor need help
i have 2000 b5 with a blown motor i found another motor but the car that it is from had a automatic transmission i have a manual transmission. will the engine match up with my transmission? or will i need an adapter? or is it not even possible?
Old Apr 11, 2011 | 09:34 PM
mschneidie's Avatar
They will not match up easily. The manual engine has provisions for the pilot bearing, while the automatic one does not (the difference is in the crank). The crank can be machined to accept the pilot bearing, though.
Old Apr 11, 2011 | 10:25 PM
FASTER's Avatar
Tech Slut
I think the last time this topic came up, it was decided that an aftermarket pilot bearing of the appropriate size could be used.
Old Apr 12, 2011 | 02:49 PM
ne idea were i could acquire one of these bearings or the size? can i use the crank of my engine? or do i need the bearing
Old Apr 12, 2011 | 03:40 PM
FASTER's Avatar
Tech Slut
You should seriously paypal me 10 bucks for the amount of time I just spent looking for this but anyway, here is a quote from Mike that gives the best info. If you're still confused I would pm him.
Originally Posted by Mike-2ptzero
Here is Chris's DIY, this was done on his 2001 A4 1.8t which has a 06A block while you have a 058 block. So there might be a slight diffence in the crank flanges.
http://www.audizine.com/forum/showth...ual-Conversion
Picture of the bearing he used as a pilot bearing. I have another customer that lives here in socal that did the tip to manual swap on her B5.5 Passat 1.8t. She too used the same bearing and also went with a CM clutch/flywheel kit.
Info for the bearing
-$19 Pilot Bearing from www.zorkos.com PN#A-6941
If I had the specs for the bearing I could most likely get it right from Clutch Masters.
Old Apr 12, 2011 | 04:33 PM
thanks man
thareals4
Jan 10, 2011 08:45 PM
myeeri15
Mar 22, 2009 07:59 PM
PlatinumX987
Sep 4, 2007 08:27 PM
teckm3
Mar 15, 2007 06:37 PM
Budcan
Mar 16, 2006 02:16 PM
