Boost gauge tutorial
Old Aug 30, 2009 | 10:39 PM
yuriy's Avatar
Default Boost gauge tutorial
Coest effective, nice looking boost gauge Made this today while installing mine.Here is the DIY:
http://www.keepandshare.com/doc/view...d=1344879&da=y
I have one question though, when im driving nice and slow, going around 30-40mph my gauge shows 0 or 1 psi. when i step on the gas though it spikes up to 10 and stays that way untill i slow slow down or release the gas. Is this how its supposed to work? The gauge is mechanical by the way.
Old Aug 30, 2009 | 11:02 PM
ghost6303's Avatar
one thing is i wouldnt run the wires like you did. if you want them fused, run them behind the fuse pannel and connect them the right way to one of the unused fuse holders and put a 10 or 15a fuse on it. if you dont care about a fuse (i didnt) connect them to the 75x main buss under the dash. other then that it looks pretty good.
if your car is a manual, when you are cruising in gear your gauge should show -20ish in/hg when you take your foot off the gas. if your gauge doesnt show lower then 0 then it wont move until you push on the pedal hard enough to make your turbo spool up. if you have an auto it might not work that way. i dont know though.
Old Sep 9, 2009 | 08:08 PM
Gigantor's Avatar
When I did a quick install to test for leaks, I noticed that the line I tapped (at the front of the IM closest to the front of the car) is only producing vacuum. So when the gauge is hooked up, I'm not showing boost (I bought one with boost only, so not seeing vacuum either). Is there a better place to install?
Old Sep 9, 2009 | 08:14 PM
Broncoman75's Avatar
nope. that is the place to install the vacuum line.
either you did something wrong, or have a leak in your line to your gauge, or you are making no boost.
Old Sep 10, 2009 | 08:50 AM
Gigantor's Avatar
Turns out it just wasn't making boost while sitting still. Not sure why, but I know I should be making ~18 psi. Right now it topped out at 5 psi, which is lower than stock. So I have to find that pesky leak.
Old Sep 10, 2009 | 11:01 AM
MrPibb's Avatar
Hmmm this sounds oddly close to the problem i'm having with my boost, only i'm getting like 2 PSI when i mash the peddle and a butt load of vacuum at idle. How do i check for the leak?
Oh and BTW sweet gauge fitting, looks really nice. This maybe my solution to my lake of gauge pod problem.
Old Sep 10, 2009 | 03:40 PM
yuriy's Avatar
Diring idle, the vacuum should be between 20-23. You wont be getting much boot while idling even if you press the pedal down hard. Press the pedal down like that on the road while driving and you'll see the arrow quickly jump to 10psi, if you're stock.
Old Sep 10, 2009 | 08:42 PM
um yeah. you arent supposed to boost at idle. the engine needs to be under load and above idle to start building much boost.
do a pressure test now that you have a gauge and fix any leaks you find.
Then if you're like me you still only boost stock pressure and start looking into a
GIAC chip or something that works since my speedtuning one doesnt...
MrPibb: go to audidiy and look in there for how to do a boost leak test.
you need an air compressor or an air tank that you can fill up at a gas station to do it correctly.
to4xxx
Jun 8, 2012 11:56 AM
slackerscott04
11
Feb 21, 2007 04:46 PM
Soley4pres
Jan 31, 2007 04:08 AM
fenderstrat1184
Dec 21, 2006 02:35 AM
s4me
May 18, 2005 08:39 PM
