Boost leak results.... questions
Did a boost leak check on the a4 this weekend. Ive done them before on other cars but this is my first time on this one. I used a similar method to the tennis ball way, but used a piece of pvc instead. I took off the egr and plugged it as well.
My problem is that it sounds like the air is going directly out the turbo soon as i put air in, and thus cant build up pressure. Any ideas?
Car runs a little weird until it builds up full boost (18psi), and in third gear at 5.5k rpm the boost falls to 5 psi. Any suggestions would be great, thanks!
Also, no codes and car does have 132k on it, stock turbo. When accelerating from a stop the car seems to pulse and jerk a little unless you have it floored. Chip is REVO too. Thanks again!
