boost leak test gave weird results
Ok, so I've got 2000 a4 1.8t quattro 5 speed and I've put GIAC chip and the 710N recently.
After that, whenever I push hard on gas, around 4000rpm I hear some crackling or rattling noise (I would say plastic, not metal sound) and acceleration become weak. And it was getting worse over the time - acceleration almost got back to stock now. (Yes I know I need to get a boost gauge - may be next week).
So it sounded like a boost leak to me (may be some rubber tube ruptured after I've got bigger boost with the chip?) and I decided to do a boost leak test. I was following these instructions: http://forums.audiworld.com/a4/msgs/1659806.phtml
After starting to pressurize the system I could not hear any air leaks but the pressure would not go up!
Instead, all I could hear was some sort of bubbling and liquid dripping sound coming from somewhere below the turbo (may be oil bubbling in the oil pan?) This was weird!
So WTF was that? Please help, I'm loosing my mind.
ORIGINAL: The Bishop
if it sounds like plastic and only happens under acceleration, I would bet that your dv is going bad. Get a 710n and that should help.
Yep, I've got new 710n and it looks ok visually. Can it be n75?
The fact that I can't put any pressure into the system under the boost leak test (and I hear that liquid bubbling instead) is very strange to me. Looks like the air is going the wrong way somewhere...
ORIGINAL: mozzancolla
me no read so good
me no read so good
me just likes to step on the gas, just tel me please woz wrong wiz ma car, me will be grateful
