Compression test results & questions
Old Mar 24, 2008 | 06:55 PM
Harbinger's Avatar
Default Compression test results & questions
Car is a 2001 A4 1.8t fwd tip, 85k miles.
I just did a compression test for the first time and these were my results:
cyl 1 - 135
cyl 2 - 130
cyl 3 - 130
cyl 4 - 125
Are these numberslow orabout normal?
I was checking for a blown head gasket (car is smoking white out the exhaust) I don't think the car was completely up to temp before I turned it off and ran the test, but it was smoking really bad.
Also, when running the test the pressure would build something like 45 psi on first stroke, 90 psi on second, then stay at130 psi. Is that normal, or do I haveworn piston rings?
Thanks in advance for any replies [sm=smiley20.gif]
Old Mar 24, 2008 | 07:21 PM
Bogie's Avatar
Default RE: Compression test results & questions
Pressure should build like that, but your compression #s are on the extreme low end of the range. A good range is 150-180psi. It is good that they are all within less than 10% of each other. My opinion is to do the compression check over again after the engine has completely warmed up. If the #s are stilllow, try adding a little engine oil (maybe 1/2 oz.) into the cylinder throught the spark plug hole and see if the compression #s improve. If they do improve some, you probably have worn rings/cylinders. If the compression does not improve, the air may be leaking through the valve stem seals, head gasket, etc...
Old Mar 24, 2008 | 08:33 PM
auditech79's Avatar
^^^^Couldn't have said it better myself.
Old Mar 24, 2008 | 09:33 PM
Harbinger's Avatar
Alright, I got the car up to temp and did the test again, this time the numbers were all about 140. I tried the oil in the cylinders on #1 & 2, and got 160 & 155. So I'm looking at worn rings/cylinder walls. Is it time to rebuild or is this still passable?
Also seems the source of the smoke in my original post is the turbo, it was making a death whine as I was driving the car up to temp. But I stopped the car and looked at the smoke, and it still looks white to me, not blue at all, is there any way coolant could get into the turbo?
Old Mar 25, 2008 | 11:43 PM
beem's Avatar
Try a leakdown test. It will show you where the gasses are going. They are more accurate and more informative than a compression test although you will need the proper gauge and a compressor. B.
Old Mar 29, 2008 | 06:26 PM
less_of_me's Avatar
Is there a DIY to perform the test??
Old Mar 29, 2008 | 10:27 PM
Bogie's Avatar
The compression check diy is hiding under the A4>>Good Thread Links>> section.
https://www.audiforums.com/m_689390/tm.htm
Old Mar 29, 2008 | 11:05 PM
FASTER's Avatar
Tech Slut
ORIGINAL: Harbinger
Alright, I got the car up to temp and did the test again, this time the numbers were all about 140. I tried the oil in the cylinders on #1 & 2, and got 160 & 155. So I'm looking at worn rings/cylinder walls. Is it time to rebuild or is this still passable? its on the low side, but not too bad. i wouldnt go crazy just yet.
Also seems the source of the smoke in my original post is the turbo, it was making a death whine as I was driving the car up to temp. But I stopped the car and looked at the smoke, and it still looks white to me, not blue at all, is there any way coolant could get into the turbo? there should be coolant in your turbo, but just the center block. other than that, no.
Old Mar 29, 2008 | 11:28 PM
less_of_me's Avatar
ORIGINAL: Bogie
hiding is right....very nice write up though. Wish I found it before I did it[:@]
magicturtle2
May 9, 2014 10:32 PM
DOC_DEPALMA
Oct 4, 2011 06:33 PM
B5 owns
Apr 7, 2008 12:32 AM
wood_e
Nov 7, 2006 06:35 PM
A4 the Quattro
Apr 26, 2006 09:37 PM
