boost leak test gave weird results
Old Mar 17, 2008 | 02:20 PM
mozzancolla's Avatar
Default boost leak test gave weird results
Ok, so I've got 2000 a4 1.8t quattro 5 speed and I've put GIAC chip and the 710N recently.
After that, whenever I push hard on gas, around 4000rpm I hear some crackling or rattling noise (I would say plastic, not metal sound) and acceleration become weak. And it was getting worse over the time - acceleration almost got back to stock now. (Yes I know I need to get a boost gauge - may be next week).
So it sounded like a boost leak to me (may be some rubber tube ruptured after I've got bigger boost with the chip?) and I decided to do a boost leak test. I was following these instructions: http://forums.audiworld.com/a4/msgs/1659806.phtml
After starting to pressurize the system I could not hear any air leaks but the pressure would not go up!
Instead, all I could hear was some sort of bubbling and liquid dripping sound coming from somewhere below the turbo (may be oil bubbling in the oil pan?) This was weird!
So WTF was that? Please help, I'm loosing my mind.
Old Mar 19, 2008 | 07:24 PM
Default RE: boost leak test gave weird results
Hey, so no one knows what can be wrong with my car?
Any ideas, please?
Old Mar 19, 2008 | 07:28 PM
The Bishop's Avatar
if it sounds like plastic and only happens under acceleration, I would bet that your dv is going bad. Get a 710n and that should help.
Old Mar 19, 2008 | 07:30 PM
A4speed's Avatar
without knowing your vacuum level i couldn't make any recommendations since someone can only guess... u need to get that boost gauge!
Old Mar 19, 2008 | 07:31 PM
A4speed's Avatar
ORIGINAL: The Bishop
he said he recently installed a 710n
Old Mar 19, 2008 | 08:19 PM
Yep, I've got new 710n and it looks ok visually. Can it be n75?
The fact that I can't put any pressure into the system under the boost leak test (and I hear that liquid bubbling instead) is very strange to me. Looks like the air is going the wrong way somewhere...
Old Mar 19, 2008 | 08:25 PM
The Bishop's Avatar
me no read so good
Old Mar 19, 2008 | 09:32 PM
A4speed's Avatar
ORIGINAL: mozzancolla
it could be...
Old Mar 19, 2008 | 09:53 PM
me no read so good
sorry ma man, me canno write so good either
me just likes to step on the gas, just tel me please woz wrong wiz ma car, me will be grateful
2fast4u66
Oct 19, 2009 10:16 PM
josh_easlon
Jun 10, 2009 12:14 AM
oldgearhead
Aug 18, 2008 08:18 AM
erikas3
Feb 12, 2008 08:15 PM
98A498
Dec 19, 2006 12:44 AM
