boosting when shifting
Old Jun 10, 2010 | 08:09 PM
A4 2000's Avatar
The only other things I can think of is there's something wrong with the wastegate, n75, or there's something else causing a slight boost leak.
Old Jun 10, 2010 | 08:20 PM
ocielz's Avatar
found this
http://www.youtube.com/watch?v=xA2wAJUdxrs
http://www.youtube.com/watch?v=Gf_RiJRwFvE
heres mine
http://www.youtube.com/watch?v=9FYSdygFwNg
well my gauge shows vacuum when shifting all the way to 30 vacuum is that normal or should it at least boost when shifting even a little?
Old Jun 10, 2010 | 08:23 PM
ocielz's Avatar
n75 valve i changed a while ago from factory to the n75 racing valve, no difference. wastegate holds suction on the line that comes out. any other way to check the wastegate?
ive found this part slighty cracked, doubt thats the reason.
http://www.ecstuning.com/Audi-B5_A4-...85_B/ES277667/
Old Jun 15, 2010 | 12:25 PM
shortyxc's Avatar
You mentioned you got new plugs. Are you sure they were gapped correctly? Makes a bigger difference than you would think.
Old Jun 15, 2010 | 01:20 PM
ocielz's Avatar
i checked the plugs and they were @.038, so i gapped them to .028. cars feels a little bit more stronger, felt the difference right away.
Old Jun 16, 2010 | 11:19 AM
shortyxc's Avatar
Damn! .038!? That is way off. Stock they should only be at .032. Glad it seems better now though
Old Jun 16, 2010 | 10:32 PM
ocielz's Avatar
That corner hose doesn't have to do with boost, does it? I ordered the piece to replace from ecstuning. Pricey for such a small piece.
Old Jun 17, 2010 | 11:10 AM
  #18
shortyxc's Avatar
Corner hose? Corner in reference to what? Pics?
Old Jun 17, 2010 | 11:37 AM
  #19
ocielz's Avatar
The little hose on the ecstuning website, I placed the Website earlier.
Old Jun 17, 2010 | 01:42 PM
  #20
shortyxc's Avatar
I believe it will help a little bit if it is the hose I am thinking of. It is expensive though
Warny
May 17, 2012 07:38 PM
boycey
Mar 29, 2008 10:16 AM
nokiamutt
Dec 14, 2007 11:42 AM
Quattro_1.8t
Aug 1, 2007 02:25 AM
Dj Spiel
Dec 5, 2006 05:57 AM
