Brake fluid
Old Mar 31, 2012 | 08:55 AM
morpheous's Avatar
Default Brake fluid
Can one use Dot 3 brake fluid on a 01 A4 B5? Or is there another proprietary fluid that Audi uses for its brake system?
And if one uses Dot 3,will it harm the brake system,opposed to Dot 4?
Old Mar 31, 2012 | 09:16 AM
M5S5's Avatar
Tech Certified
Just use dot 4!
Dot 3 has a lower boiling point then dot 4. Most all European cars call for dot 4.
How much money are you planning on saving by using dot3 ????
Old Mar 31, 2012 | 09:31 AM
morpheous's Avatar
Well,it wasn't used on purpose,i happen to have a bottle of Dot 3 laying around and I didn't recall if a B5 uses Dot 3 or Dot 4 so I told my mechanic to flush the fluid and put in the fresh Dot 3,will it harm the brake system?
Should I have him flush it again and have him put in the Dot 4? Or I can just keep in the Dot 3 and use Dot 4 next flush?
Old Mar 31, 2012 | 10:39 AM
bshusted's Avatar
Dot 3 and 4 are compatible, so there wont be any damage to the brake system. As was mentioned previously Dot 4 has a higher boiling point than 3. As it is with the fresh fluid in it now, the boiling point will be much better than the old fluid removed so long as the new fluid came from a sealed container. Brake fluid readily absorbs water, which is what lowers the boiling point. You should never used brake fluid from an open container. Unless you plan to track the car, just leave it in and flush it with Dot 4 next time.
Old Mar 31, 2012 | 10:40 AM
M5S5's Avatar
Tech Certified
Your mechanic is not too bright if he put in Dot3. IT SAYS TO USE DOT 4 RIGHT ON THE CAP.
Find your self a technician , mechanics work on trucks.
Old Mar 31, 2012 | 10:53 AM
morpheous's Avatar
Alright,i'll use Dot 4 next time..i'll take the blame for it,being i gave him the Dot 3,so big deal.
I was just concerned that Dot 3 would harm the Brake system is all.
B5 Audi
Nov 27, 2009 05:24 PM
AR15Texan
Jun 10, 2009 12:24 PM
jakej
Nov 12, 2008 08:55 PM
