Brake fluid leak off caliper
Old Apr 13, 2009 | 04:38 PM
dwnwrdspirl's Avatar
Default Brake fluid leak off caliper
Its leaking out of the e brake pivot plate that looks like it bolts to the caliper. Do i need a new caliper or is this a rubber piece that can be replaced? Thanks for the help!
Old Apr 13, 2009 | 05:28 PM
hiwords's Avatar
can you post a pic? the only place fluid might leak out of a caliper is the bleed hole or the lines.
Old Apr 13, 2009 | 06:14 PM
Here you go. It looks like when the e brake is pulled it twisted and slides in. It isn't holding pressure when the brakes are applied and fluid leaks around it. I don't know if this can be fixed or if it means a new caliper?
Old Apr 13, 2009 | 06:17 PM
turbo kraut's Avatar
Tech Guru
i would just get a new one if there is no pedal feel
Old Apr 13, 2009 | 08:11 PM
hiwords's Avatar
ya you'll need a new one if it's leaking from there.
well you're in luck because i have a set of calipers that just need the rebuilt kit from MJM. pm me if you want them. and yes they are the rears like the one in your pic
Old Apr 13, 2009 | 08:43 PM
thanks but i already ordered a replacement.
CyphrMedic
Sep 5, 2010 12:55 PM
akirk
Dec 9, 2008 05:57 PM
jakej
Nov 12, 2008 08:55 PM
moosefist
Feb 21, 2008 10:23 AM
TopGUn86
Aug 16, 2007 08:57 PM
