Brake squeak at low speed
Old May 8, 2008 | 05:53 PM
compmanben's Avatar
Default Brake squeak at low speed
OK I haven't looked into this yet, but I have a sqeak coming from what I believe is the front left or front right brake. Here's what happens - at low speeds (less than 20) I'll hear a periodic squeak, but it goes away if I hit the brake. I believe I have plenty of pad left... Any suggestions for things to try?
Old May 8, 2008 | 06:55 PM
hiwords's Avatar
Default RE: Brake squeak at low speed
ok at low speeds, you hear a squeak b4 you apply the brakes but it goes away after you apply the brakes?
Old May 8, 2008 | 07:03 PM
compmanben's Avatar
Correct
Old May 8, 2008 | 07:42 PM
hiwords's Avatar
hm maybe your pads are touching and when you apply the brakes, it pushes the pads back towards the calipers. check your inner pad, it might be slighty loose. also spray your brakes with brake cleaner.
DewAudiA4
Mar 18, 2013 11:04 AM
03A41.8T
Apr 8, 2008 10:13 AM
SuperVan
Mar 30, 2008 03:19 PM
brrman
Jun 1, 2007 11:06 AM
turboavant
May 6, 2007 04:47 PM
