Brakes issue
Old Jul 10, 2008 | 04:56 PM
CycloSteve's Avatar
Member
Default RE: Brakes issue
OK here is the easy way to see if it is the booster.
1. With car off pump the brake pedal until it does not move any further down.
2. Turn on the car
3. If the pedal goes down immediately, then the booster is OK, if it does not go down at all or slowly, then either the booster is bad with a torn diaphram, or you are not getting vacuum from the motor.
4. If it did not move, first check the vacuum line to the booster to ensure that it is pulling vacuum when the motor is running. Can also check by disconnecting the vac line with motor just shut off and residual vacuum should give you good bleed-down whoosh.
No cost, and a 30 second check will either confirm that this is part of the problem or not.
Cheers,
Steve
P.S. In anycase get the CV fixed
Old Jul 11, 2008 | 06:02 PM
Tweaked's Avatar
ORIGINAL: CycloSteve
Aw, yeah, the booster! Duh, why didn't I think of that? Good thinking.
nelson0639
Dec 8, 2014 04:44 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
eddy123
Jan 14, 2010 08:24 AM
MistaGanja
Nov 29, 2007 02:10 AM
