Broken down
So I had a lot of popping and clunking in the front end leaving Walmart made it about 2 miles down the road then grinding clunkin and that was it no movement in any gear just grinding sound stuck at a stop sign. Cvs still look attached to transmission haven't had towed yet so can dig in yet any ideas. I can throw it in any gear and take foot off clutch and won't stall out or anything
Ok well if it is I have a whole drivetrain from a 97 5 speed with whole suspension would that trams work there different codes but both 5 speeds mines a 96 the replacement is 97 both are 2.8l 12v 5 speeds
Because mines at 240k on it and this setup has 140k on it so I'd rather just swap everything for the less mileage setup and I need to replace my rack and pinion cause that just started to go this week then bam this happened so it will be easier to drop the whole engine cradle with trans and motor setup and change the rack and put the less mileage stuff in it
derZeck
Feb 22, 2012 02:53 PM
EvanF
B7 Models
Jun 23, 2010 04:41 AM
paintballcs
Dec 23, 2009 08:26 AM
