Bulb Warning light comes on now after relaying headlight system....??????????
Old Feb 20, 2011 | 09:58 AM
junkeravant's Avatar
Default Bulb Warning light comes on now after relaying headlight system....??????????
I have done this mod 100 times & have never had this happen before.
I put 2 30 amp relays- 1 for the High beam & 1 for the Low beam. Each relay is protected by a 30 amp fuse. The power is from the Battery and the relays are grounded to the battery. The Trigger wire is from the headlight switch.
Each headlight is wired straight from the relays. The Bulb Warning Light comes on because the resistance is not high enough. The only thing I can think of is that I cut the wires on the passenger side since they are no longer needed since the that side is being fed from the relay now. Any ideas where I went wrong?
Old Feb 21, 2011 | 09:53 AM
Sohcvtec1995's Avatar
run 2 separate harnesses, one for the right, and one for the left.
Old Feb 21, 2011 | 10:13 AM
Default Have done that...doesn't work.
I have been told to jump the Light Module relay. But I have no idea what # the relay is.
Old Feb 21, 2011 | 10:15 AM
ImTheDevil's Avatar
Look in the stickys up top - the other day I stuck a post from anOther member with a breakdown of the relay panels.
Dalakian
Oct 24, 2012 11:47 PM
slowak09
Sep 6, 2012 12:12 AM
hankeester
B7 Models
Apr 10, 2011 07:03 AM
matant01
May 22, 2008 12:22 PM
snow4fun
Nov 6, 2006 01:21 PM
