A/C Problems!
Old Jun 19, 2008 | 02:49 PM
i2onnel's Avatar
Default A/C Problems!
I never really used the A/C on my car ever until trying out recently, and that thing just does not get cold! I feel air blowing out, but I don not feel it getting cold...
Do I just need to refill that R#### something? If it is that, how exactly would I do that? Where is the place to put it in?
If it is not that, what else could it be?
Thanks in advance!
Old Jun 19, 2008 | 05:28 PM
Dallas09's Avatar
Default RE: A/C Problems!
Its R-134a, you could connect a pressure gauge to the low pressure side (service manual shows which one, i think its the right side valve and they are different sizes anyway, however you wouldnt wanna connect to the high accidently especially if you decided to fill it.) It could be low (so then you probably have a leak) or it could be a control head issue so vag HVAC or go to audiworld.com and find the codes youcan find through the control head (you dont need vag for that). Check to make sure you hear the compresser come on when you turn it on, if you dont it could either be extremely low, too high,the pressureswitch itself, ac relay, or compresser/compresser belt might be bad.
Old Jun 20, 2008 | 11:15 AM
i2onnel's Avatar
Does anyone wanna get together and check it out?
I'm dying in this weather... I'll buy beer/marijuanaaaa! =]
[align=center] [/align]
Old Jun 22, 2008 | 03:06 PM
david9999's Avatar
First off check if year hear the AC clutch engage. Check the AC fuse. check tha the secondary electric fan switches on. The electric fan at the radiator often burns out and the AC won't work well without it.
Get hold of a vagcom and check the HVAC and flap valves.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
