Can Anyone Identify this Mysterious Wire
Old Jul 15, 2008 | 10:44 PM
audi_n00b's Avatar
Default Can Anyone Identify this Mysterious Wire
So I was looking under my car and found this green wire with a yellow stripe on it and it inside some black tubing. the only problem is the black tubing is melted and the wire is starting to get destroyed. I snapped some crappy pics so maybe someone could help.
This is the damage:
Its plugged into this green and purple connector thing located on the passenger side of the car:
It then runs up underneath the bumper to the drivers side of the car where it connects to another purple and green plug:
Any help would be appreciated.
Old Jul 16, 2008 | 02:06 AM
Dallas09's Avatar
Default RE: Can Anyone Identify this Mysterious Wire
Im sure someone will know for sure but i always thought it was for the coolant fan.. Id just unplug it and see what happened if it were me.
Old Jul 16, 2008 | 02:10 AM
techbod's Avatar
im guessing its the connector for the ABS sensor
Old Jul 16, 2008 | 02:42 AM
audi_n00b's Avatar
So in theory if this wire were damaged my ABS wouldn't function properly?
Old Jul 16, 2008 | 03:14 AM
techbod's Avatar
yep but to confuse things a little more, your first picture shows a damaged wire above the plug connector and second shows only the connector so which one are you talking about, and the ABS CEL would be on if it were that wire and probably wouldn't function at all
Old Jul 16, 2008 | 07:09 AM
techbod's Avatar
site issues causing problems in edit mode[:@]its the wire for the cooling fan
been trying to edit that all morning
Old Jul 16, 2008 | 09:50 AM
ghost6303's Avatar
in the first pic it looks like its been rubbing on your a/c belt enough to get thru the plastic sheathing, just wrap it up in some electrical tape and zip tie it out of the way of any belts or fans
Old Jul 16, 2008 | 03:16 PM
audi_n00b's Avatar
Thanks techbod. I was starting to doubt that it was related to the ABS because the ABS light wasn't coming on. And ghost, I just taped it up this morning and I've been searching around my house for a zip tie. Thanks for all the help guys.
starving030
Feb 27, 2014 08:12 AM
Bret
Sep 1, 2013 12:24 AM
Twistedfreedom
Oct 27, 2010 02:06 AM
Nevalite
May 9, 2010 10:54 AM
ladendale
Mar 20, 2006 09:03 AM
