Can timing belt replacement lead to P0171?
Old Oct 29, 2008 | 02:56 PM
yokar's Avatar
Default Can timing belt replacement lead to P0171?
Hi,
I've a 2001 A4 1.8T. Two weeks ago I got the following service/repairs done:
- 80K mile serive
- timing belt and water pump
- front cv boots, tie rod and alignment
- back brakes and rotors
- throttle body replacement to take care of surging of engine when idling
After the service/repairs, my check engine light came on. I took the car to the repair guys and he said it's P0171 bank1 system running too lean. He reset the light and asked me to drive for a bit more. This week the light came back up with same code. The repair guy thinks it's the O2 sensor or catalytic converter.
I was wondering if the service/repairs I got done had anything to do with this check engine light. There was no check engine light before these repairs.
Thanks,
Old Oct 29, 2008 | 04:44 PM
Sick Boy's Avatar
got the same thing on my 01 1.8t its you o2 sensor
Old Oct 29, 2008 | 06:14 PM
redline380's Avatar
Legal Moderator
mine was a maf. you should try it out too
Old Oct 29, 2008 | 06:57 PM
Dallas09's Avatar
Check VAC lines first, much cheaper fix, thats what mine was. The hose running from the intake to the diverter valve, the leak was real loud so i spotted it right away.
Old Oct 30, 2008 | 10:23 PM
yokar's Avatar
thanks guys...
looks like it's some air-meter as per the mechanic... does it take about $300 for it? can I try to fix it myself?
Old Nov 2, 2008 | 02:34 PM
Dallas09's Avatar
Well Air Meter isnt very specific but your mechanic is probably talking about the MAF and it isnt that hard to replace.
Old Nov 2, 2008 | 07:15 PM
yokar's Avatar
borrowed OBD2 scanner from a friend and hooked it up... looks like P0171 is gone and now it shows P0102 (Mass or Volume Air Flow Circ Low Input)..
Old Nov 2, 2008 | 10:08 PM
Dallas09's Avatar
Well its likely p0171 will come back (that code only occurs after a longer term) becuase the mechanic probably cleared the codes to see what comes back. Its either vaccum lines or MAF.
Timon
Jul 7, 2012 01:29 AM
Sparty31
Dec 21, 2010 01:33 PM
T-Roc
Oct 29, 2009 09:36 AM
np07
Jun 6, 2007 10:15 PM
