can you run a b5 a4 1.8t open turbo
You have to have an intake since the ecu needs the maf reading and is completely dependent on it since there is no map on your car.
you need one of these http://intakehoses.com/Merchant2/mer...gory_Code=CHEW
The 2000(ATW) which is what he has does in fact have a MAP sensor, it just doesn't have a wide band 02 sensor.
The 97-99.5 did not come with a MAP sensor.
its a 00 i had a autobauhn88 intake missed spelled that sry but it wont fit on the t3 compressor side and if i get an adaptor it comes out to far and hits the ac fan right now i got a jerryrig setup with slinky pipe but with that setup i took the crank case think off that goes into the intake and put a filter on it i also dont have the n75 hooked up again yet but the gas fume line is hooked up and dissconected the other side of the bov
4biddna4
Sep 12, 2011 10:30 AM
a6avant
Jul 5, 2007 03:52 PM
nickellis14
Mar 14, 2007 07:49 PM
JETSPEED333
Mar 14, 2007 07:32 PM
