Car Vibrating in the back.
I have a 2001 Audi A4 2.8 Quattro.
The problem I am having is when I take off from a stop I am feeling a vibration coming from the back of the car. It only happens when I take off from a stop. Not sure what is it. I had the wheel balance and rotate and still the same problem.
Also, I'm hearing squeaking noise coming from the back while I'm driving, does not matter the road surface. Sometime I hear the squeaking it sometime I don't. If I push down on the trunk while the car is park I can hear the squeaking now. Can anyone point me in a direction of what could be the problem.
Thanks,
Kevin
Thanks,
Kevin
Can you yank the back wheels off and see what kind of shape the shocks are in? i.e. is there any oil/fluid leaking out on to the main shaft? and while you're down there check the control arm(s). I've never replaced the rear control arms but I think it's more or less one upper piece and one lower piece - as opposed to the front arms which have 5 or 6 pieces each side
mcanedo92588
Sep 4, 2013 07:32 AM
