car wont go above 4000rpm
Who told you this? Shifts are (should be) dictated by engine load at X rpm's in D. In tip, you should be able to hold every gear to redline if you want to regardless of engine load. I mean it wont let you shift to 4th gear @ 15 mph, and it will upshift at/after redline to keep you from over reving, but you should have pretty much full control. I'd have to guess your TCU is fooked. Get ahold of someone with vag com, or get vag com and scan the TCU for faults. Depending on what scanner places like autozone use, their equipment MIGHT be able to get into the TCU, but don't count on it. Vag com or dealer diag. is maybe the only way to access the TCU. Is there any way you can get a video of your RPM's while this is happening? I gotta see this!
Jim Matthews
B8 Models
04-16-2012 10:18 PM
Jim Matthews
04-16-2012 08:21 PM
