CEL Light, ran diagnostic and have codes. Need help comprehending!
Old Jun 24, 2010 | 07:12 PM
ThanksInAdvance's Avatar
Default CEL Light, ran diagnostic and have codes. Need help comprehending!
Hey everybody, just signed up today after reading some of the threads and realizing this is the perfect place to find help figuring out whats wrong with my car. So I've had my 2001 B5 A4 1.8t no quattro for about 3 years. Bought it with 110k miles on it and it has around 145K now. For all I know it seems like the car was kept in good shape mechanically before I had it. For the 35k that I've driven it I've been pretty good about oil changes on time and have had some fairly simple repairs done by a certified mechanic. So about 1000 miles ago the axle and some front end work needed to be done because the bearings were worn down (?) i think. Now the other day the check engine light comes on and the car starts to sound awful, almost like a lawnmower. The turbo sounds like its whistling and it feels like the car isn't getting the same power it used to. I'm worried because I topped off my car with 2 qts of 5W-20 oil when I was on a roadtrip and I didn't realize thats not the right oil. So i took it to a mechanic and had them drain the oil, change the filter and put the right oil in. I also had them run a diagnostic because of the check engine light. Mechanic called and said theres a bunch of things wrong and that the repairs will be more expensive then the car is worth. So now I hope one (or more) of you can help me understand what these codes mean and what is actually wrong with the car. Heres the list and thanks in advance for your help (and for reading my lengthy post).
16712: Knock Sensor 1 GG1 Bad
16717: Knock Sensor 2 G66 Fault
17735: Knock Control Cylinder #3 Limit Attained
16395: Bank 2 Camshaft Adjustment Malfunction
16955: Brake Light Switch Fault
17956: Control Valve Boost Pressure Malfunction, Turbo Malfunction
Thanks again everyone. Also sorry if I broke the rules but I tried to follow all of them.
Old Jun 24, 2010 | 10:14 PM
02A6Beau's Avatar
TRY CLICKING HERE
Good stuff there in the ross-tech wiki. gives you some pointers in trying to get those issues taken care of.
good luck
let us know how it turns out
slufan83
May 18, 2008 07:55 PM
alexgsi2000
Mar 5, 2007 08:21 PM
Siren
Feb 12, 2007 08:49 PM
big blue
Sep 19, 2006 07:19 AM
daveplot
Jul 21, 2006 05:52 PM
