changed suction pump, and it's STILL not working!
Old May 11, 2008 | 08:09 PM
PRican1.8T's Avatar
Default changed suction pump, and it's STILL not working!
okay, i got my car diagnosed by Audi and they said i needed a vacuum valve and a jet pump valve(suction pump). i just replaced them both new and now it's STILL shaking after i unplugged the battery overnight to reset the computer. what do i need to do?!
Old May 11, 2008 | 08:40 PM
sineo's Avatar
Default RE: changed suction pump, and it's STILL not working!
You need to go to AutoZone and have them scan your car (free) and then post the codes here or plug them into the search.
Old May 11, 2008 | 10:55 PM
PRican1.8T's Avatar
i've gotten the same codes. p0301-p0304. went to dealer and they said i needed vacuum check valve and jet pump valve (suction pump) so i replaced them, and it's still shaking on cold start! i don't understand!
Old May 12, 2008 | 01:03 AM
sineo's Avatar
What year? Could be coilpacks or spark plugs.
Old May 12, 2008 | 01:47 AM
PRican1.8T's Avatar
i've changed everything. fuel injectors, spark plugs, coil packs, ECT sensor, MAF is good, and now the vacuum check valve and suction pump, still, nothing
Old May 12, 2008 | 10:08 AM
auditech79's Avatar
Well there are 4 vaccum check valves in your engine, did you replace them all or just one? Does your engine sound like its sucking in air or not?
Old May 13, 2008 | 12:47 AM
PRican1.8T's Avatar
i only replaced one cause the dealer said i needed one and it was obvious which one i needed to change (i also blew through it after i took it out to check and air went through both sides) the suction pump was leaking a bit of oil. i can't really hear anything different except when i give it gas you can hear that it's "misfiring"
Old May 13, 2008 | 10:13 AM
auditech79's Avatar
You might have an ignition problem then, you need to have it scanned again, just go to autozone if you don't have a VAG COM, they can pull the codes for free. Then post the codes back here.
Old May 14, 2008 | 12:14 AM
PRican1.8T's Avatar
would an ignition problem fix itself after the engine's warmed up?
Old May 16, 2008 | 06:59 PM
PRican1.8T's Avatar
bump please!
zoewagner
Aug 15, 2013 10:03 AM
ou2mame
Mar 23, 2012 05:47 AM
BesI
Jul 13, 2011 01:28 AM
theflash
Aug 22, 2010 02:42 PM
irishaudi
Sep 3, 2007 01:32 PM
