Changing timing belt question
Old Dec 20, 2014 | 03:40 PM
HolyokeAudi's Avatar
Default Changing timing belt question
I was talking to my buddy and he said he changed a A4 timing belt without taking off the front bumper etc etc is that possible? Maybe 2002 and up?
Old Dec 21, 2014 | 02:48 PM
AudiInfantry's Avatar
It's probably doable, but much easier to move the front end into the service position to do it. I couldn't have changed my alternator any other way. There isn't a lot of room to put a belt on.
Old Dec 21, 2014 | 06:21 PM
mtroxel's Avatar
Possible? Probably. But why would you? You'd add a good two hours to the job doing it that way....
If it's possible.
Old Dec 21, 2014 | 10:59 PM
hartsoe1's Avatar
He might be able to change the timing belt, but I bet he didn't change the tensioner, roller, or water pump.
Old Dec 21, 2014 | 11:05 PM
hmmmm thats a good point I am not sure how he would of changed the water pompa rollers etc etc...
Old Dec 22, 2014 | 07:42 AM
The next time I have the front end off, i'll be upgrading pulley's, timing job, and putting a sweet RS4 bumper on the front.
Taking the front end off took 30 min, the alternator about an hour, only because I have big hands and it's a tight fit, and then another 30 min to slap it all back together, fill it with fresh coolant and fire it up.
Youtube, google and my haynes saved me money again. The first time was a clutch. It's like saying I could change the clutch without taking the axles off, the exhaust down, and unbolting the trans mounts. I can also see why the stealership charges thousands to do a clutch job. PITA, so why make it any harder than it has to be?
HolyokeAudi
Dec 31, 2014 05:26 PM
Audiguruforyou
Sep 20, 2011 01:31 AM
drewcafua
Jan 9, 2011 10:19 PM
sollyd25
Jun 6, 2009 03:41 PM
RobNVA
May 9, 2007 02:56 AM
